Nested If...Then
I am using the RCTIME command to determine the
operational status of a variable reluctance speed
sensor during shock and vibration testing. My goal is
to measure the resistance of the winding to ensure
that during the testing it does not open or short.
Also, I need to determine if the winding shorts to the
metal enclosure of the speed sensor.
I am thinking that I can use the TCTIME to determine
the static values when the sensor is OK. When RCTIME
returns the result variable, the value would then be
evaluated and then a LED whould be turned ON if one of
my three test conditions is met.
My question is can I use the IF...Then command as a
nested function. If so how would I go about doing it.
John DeFeo
Director, Engineering
Motion Sensors Inc.
PH: 252-331-2080
FAX: 252-331-1999
e-mail: jdefeo@m...
web-site: http://www/motionsensors.com
__________________________________________________
Do you Yahoo!?
Yahoo! News - Today's headlines
http://news.yahoo.com
John DeFeo
Motion Sensors Inc.
PH: 252-331-2080
FAX: 252-331-1999
e-mail: jdefeo@m...
Do you Yahoo!?
In Pbasic, the only thing you can do with an IF is to GOTO a label. So,
If x=0 then foo
Is the same as the illegal statement:
If x=0 then goto foo ' not legal syntax
So you have to "unroll" your nesting to a series of labels. One handy
trick is to reverse your test. For example if you want to write:
IF x=0 then
gosub xyz
debug ?x
END IF ' not legal syntax
You might considering writing:
If x<>0 then endif01
gosub xyz
debug ?x
Endif01:
Or if you wanted to write:
IF x=0 then
gosub xyz
debug ?x
ELSE
gosub abc
debug ?y
ENDIF ' all illegal syntax!
You might try:
If x<>0 then else01
gosub xyz
debug ?x
goto endif01
Else01:
gosub abc
debug ?y
Endif01:
Not perfect, and you have to train yourself to remember that the
condition is reversed. That is, the first block of code is for x=0 and
the 2nd block is for x<>0!
Of course, the opposite of < is >=, <= is >, etc.
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: John DeFeo [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DvwjF7HRq_5EGw-dmAtMJu7T5ASVLMQ16DDCrM5QO-AGg3JRCcDkBgstUV7BLEYC1PChx8J9Cyq-pA]jwdefeo@y...[/url
> Sent: Tuesday, September 17, 2002 9:42 PM
> Subject: [noparse][[/noparse]basicstamps] Nested If...Then
> returns the result variable, the value would then be evaluated and
> then a LED whould be turned ON if one of my three test conditions is
> met.
> Thanks
> John DeFeo
> Motion Sensors Inc.
> PH: 252-331-2080
> FAX: 252-331-1999
> e-mail: jdefeo@m...
> Do you Yahoo!?
> from the same email address that you subscribed. Text in the
