URGENT -- Having problem, Please Help.
I am trying to write some code to read the iButton and also
interface to a GPS receiver.
I have have major problems with 'Returning from a Subroutine'.
It seems as if the Stamp resets itself when it gets to the end of
the subroutine and tries to return.
I have taken this cose from the BS2P Plus pack and am running it on
a 24 pin BS2P.
I will be very grateful for any help on this.
I have connected a 4K7 pull-up resistor on the iButton. The data
from the iButton is displayed successfull, but it them resets when
returning from the 'DisplayRom' Subroutine.
I will also try and upload the code on this site for your reference.
The code is shown below:
[noparse][[/noparse] Title ]
' File...... 1WIRE-ID=startagain for GPS.BSP
' Purpose... Reads ROM data from 1-Wire device
' Author.... Ashfaq Juna
' E-mail.... ashfaqjuna@h...
' Started...
' Updated...
' {$STAMP BS2p}
[noparse][[/noparse] Program Description ]
' Reads 1-Wire device ROM pattern. Data is displayed in DEBUG window
[noparse][[/noparse] I/O Definitions ]
OWpin CON 15 ' 1-wire
device pin
[noparse][[/noparse] Constants ]
OW_FERst CON %0001 ' Front-End
Reset
OW_BERst CON %0010 ' Back-End
Reset
OW_BitMode CON %0100
OW_HighSpd CON %1000
ReadROM CON $33 ' read ID, serial
num, CRC
SearchROM CON $F0 ' search
NoDevice CON %11 ' no device
present
[noparse][[/noparse] Variables ]
idx VAR Byte ' loop
counter
romData VAR Byte(8) ' ROM data from DS1820
devCheck VAR Nib ' device
check return ocde
[noparse][[/noparse] Initialization ]
Initialize:
PAUSE 1000 ' let DEBUG
window open
[noparse][[/noparse] Main Code ]
Main:
DEBUG CR
DEBUG "Start of Code"
GOSUB DeviceCheck ' look for
device
IF (devCheck <> NoDevice) THEN DisplayROM
IT SEEMS AS IF THE CODE NEVER GETS TO THIS STAGE
WHEN IT ATTEMPS TO RETURN FROM THE SUBROUTINE "
Display Rom"
the Stamp seems to reset it self.
It goes to the DisplayRom Subroutine successfull,
but resets when it returns from it
DEBUG " It returns OK"
END
NoDeviceFound:
DEBUG "No 1-Wire device(s) present."
END
DisplayROM:
DEBUG "Dallas 1-Wire ID : "
OWOUT OWpin,OW_FERst,[noparse][[/noparse]ReadROM] ' send Read
ROM command
OWIN OWpin,OW_BERst,[noparse][[/noparse]STR romData\8] ' read serial number
& CRC
FOR idx = 0 TO 7
DEBUG HEX2 romData(idx)," " ' show ID, serial
num, CRC
NEXT
DEBUG "Returning" '********** THis is the last instruction before
the 'Return'
'********** THE STAMP THEN RESETS IT SELF
RETURN
[noparse][[/noparse] Subroutines ]
' This subroutine checks to see if any 1-Wire devices are present on
the
' bus. It does NOT search for ROM codes
DeviceCheck:
devCheck = 0
OWOUT OWpin,OW_FERst,[noparse][[/noparse]SearchROM] ' reset and start
search
OWIN OWpin,OW_BitMode,[noparse][[/noparse]devCheck.Bit1,devCheck.Bit0]
RETURN
NoDeviceFound:
END
DisplayROM:
ROM command
& CRC
FOR idx = 0 TO 7
num, CRC
NEXT
the 'Return'
RETURN
the
DeviceCheck:
devCheck = 0
search
RETURN
a 24 pin BS2P.
' Started...
' Updated...
' {$STAMP BS2p}
device pin
Reset
Reset
num, CRC
present
idx VAR Byte ' loop
counter
check return ocde
Initialize:
window open
Main:
DEBUG CR
device
Display Rom"
END
NoDeviceFound:
END
DisplayROM:
ROM command
& CRC
FOR idx = 0 TO 7
num, CRC
NEXT
the 'Return'
RETURN
the
DeviceCheck:
devCheck = 0
search
RETURN
NoDeviceFound:
END
DisplayROM:
ROM command
& CRC
FOR idx = 0 TO 7
num, CRC
NEXT
the 'Return'
RETURN
the
DeviceCheck:
devCheck = 0
search
RETURN
the problem lies in the fact you are calling the 'DisplayRom'
subroutine from an "IF-THEN" statement. An "IF-THEN" is effectively a
GOTO not a GOSUB command. This means at the end of 'DisplayRom' you
need a GOTO statement for the code to know where to go back to. Using
return does not provide the Stamp a point to return to.
Cheers
Col
> a 24 pin BS2P.
> ' Started...
> ' Updated...
> ' {$STAMP BS2p}
window
> device pin
> Reset
> Reset
serial
> num, CRC
> present
> idx VAR Byte ' loop
> counter
> check return ocde
> Initialize:
> window open
> Main:
> DEBUG CR
> device
> Display Rom"
> END
> NoDeviceFound:
> END
> DisplayROM:
> ROM command
number
> & CRC
> FOR idx = 0 TO 7
serial
> num, CRC
> NEXT
> the 'Return'
> RETURN
on
> the
> DeviceCheck:
> devCheck = 0
> search
> RETURN
> NoDeviceFound:
> END
> DisplayROM:
> ROM command
number
> & CRC
> FOR idx = 0 TO 7
serial
> num, CRC
> NEXT
> the 'Return'
> RETURN
on
> the
> DeviceCheck:
> devCheck = 0
> search
> RETURN
Thank you very much for your help.
I will ammend the code accordingly.
Just goes to show how good I am with the Basic Stamp! *S*
Best Regards
Ashfaq
--- In basicstamps@y..., "aussiecol39" <aussiecol39@y...> wrote:
> Hi
effectively a
you
Using
> Cheers
> Col
of
on
> > a 24 pin BS2P.
data
when
reference.
> > ' Started...
> > ' Updated...
> > ' {$STAMP BS2p}
> window
> > OWpin CON 15 ' 1-
wire
> > device pin
> > Reset
> > Reset
> serial
> > num, CRC
> > present
> > idx VAR Byte ' loop
> > counter
DS1820
> > check return ocde
> > Initialize:
> > PAUSE 1000 '
let DEBUG
> > window open
> > Main:
> > DEBUG CR
> > device
> > Display Rom"
successfull,
> > END
> > NoDeviceFound:
> > END
> > DisplayROM:
> > ROM command
serial
> number
> > & CRC
> > FOR idx = 0 TO 7
> serial
> > num, CRC
> > NEXT
before
> > the 'Return'
> > RETURN
present
> on
> > the
> > DeviceCheck:
> > devCheck = 0
> > search
> > RETURN
> > NoDeviceFound:
> > END
> > DisplayROM:
> > ROM command
serial
> number
> > & CRC
> > FOR idx = 0 TO 7
> serial
> > num, CRC
> > NEXT
before
> > the 'Return'
> > RETURN
present
> on
> > the
> > DeviceCheck:
> > devCheck = 0
> > search
> > RETURN
