Problem w/ serial port and running program
Greetings...
I've been using a PC to program and use a BS2 (on a BOE), and
everything seems fine and working.
Recently, I've switched to a laptop. The serial cable downloads the
program to BS2 but, as long as the cable remains connected to the
BOE, nothing is executed. I've to physically disconnect the cable in
order to run the program.
I've tried to detect any differences between the COM settings on my
PC and laptop but have not been able to detect any. There must be
something I'm missing here.
Has someone had similar problem? Any insight, help, or comment would
be appreciated.
Thank you in advance.
Said Shakerin
be appreciated.
Said Shakerin
know
my notebook is a toshiba satellite pro 4200
I look for the com configuration but nothing rare there
Thank
Mensaje original
De: saidshakerin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=78pgjd3j6hmyV7JbnQyuhTxzUlCqBAiwJAphH5yQhbN3gqU9-0I2PTBbk1cLebVbDiZsQmNJj3Ag5kJs7333]saidshakerin@y...[/url
Enviado el: s
that works for me.
Open Debug window (under Run on the menu bar). Once
you have this, you can shrink it, then download the
program, and bingo, it should work. It works on mine.
Parallax said they encountered the same problem with
Dell laptops. Mine is a ChemBook. Their solution seems
to be working just fine.
It still baffles me why the problem occurs!
Hope this helps you and fixes the problem. Let me
know.
Said
--- Jacques Morin Caballero <jacquemc@c...>
wrote:
> I had the same probem, till now I can't fixit, if
> you get an answer please letme know
> there
> Thank
Mensaje original
> De: saidshakerin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=GZCymgP2oayKKsYAL7mX0KDbm_DXz2PcoZ-PCyxJU1tMP44Fc2kCOZChkmUiViHyeKlRmcyBSDuGbln5]saidshakerin@y...[/url
> Enviado el: s
and all I did was put a debug statement in the code (which opens a debug
window) and all was well.
I posed the question to Parallax and got an answer
that works for me.
know.
> there
> BOE), and
> cable downloads the
> connected to the
> settings on my
> There must be
rate. This caused constant resets(from the DTR) line. I assume it is some sort
of
power saving feature and that polling turns it back on?
> that works for me.
> know.
