DCE and DTE?
When should either a male or female DB-9 connector be used on a
serial connection? I know serial devices can be classified as either
DCE or DTE, and I believe that determines whether you use the
male or female version.
So for example, how does someone decide that a GPS reciever
should be DCE or
DTE?
I want to standardize the GPS connectors to my flight computers,
and I want to do this the smart way (in a way that I assume is
already the standard).
I don't have a Garmin Etrex GPS receiver to look at, but I believe
it's connector is a female DB-9. Is this a standard for other GPS
recievers and how did someone determine this should be the
correct connector??
Paul
should be DCE or
DTE?
correct connector??
Paul
Normally DTE (Data Terminal Equipment) refers to a PC (personal computer) type
of device. On both 25 Pin and 9
Pin these connectors are male.
Normally DCE (Data Communications Equipment) refers to a modem type of device.
On both 25 Pin and 9 Pin these
connectors are female.
Hope this helps.
Jim
verhap@o... wrote:
> When should either a male or female DB-9 connector be used on a serial
> classified as either DCE or DTE, and I believe that determines whether you use
the male or female version.
> should be DCE or DTE?
> I want to standardize the GPS connectors to my flight computers, and I want to
> that I assume is already the standard).
> I don't have a Garmin Etrex GPS receiver to look at, but I believe it's
> standard for other GPS recievers and how did someone determine this should be
the correct connector??
> Paul
