Serin question.
Hi guys,
I posted this recently but had no responses. I doubt it baffled the
brains in this groups :-) so I'm posting it again.
I hope someone can assist me interfacing a serial module to the BS2.
The specs state the unit outputs a logic high of a maximum 0.3V and a
logic low of a minimum 0.7V. There in no mention of a logic high min
(but I presume it would be close to 0V) or maximum logic low (which I
presume would be approaching 5V).
I doubt (but am not sure) the Stamp can differentiate between high
and low if they fall into this max and min range.
I can not find reference to the exact levels the stamp requires. If
it can handle these levels all well and good.
But if it can't, can anyone suggest a simple way to reliably modify
the levels to ensure a correct read. I am not very knowledgable as
far as electronics is concerned.
Thanks in advace
Col
Thanks in advace
Col
where you can measure the levels or observe them on an oscilloscope?
What device is it? What baud rate?
The stamp switching threshold is around 1.3 volts.
If you really need to set a threshold at 0.5 volts, you can do so
with a comparator chip. Feed 0.5 volts into the (-) input, and feed
the signal into the (+) input, and viola`, the full range signal will
appear on the output. You might be able to get by with a single
transistor as the threshold detector, base to signal through a ~1kohm
resistor, emitter to common, and collector through a 10k resistor to
+5 volts. That signal is right at the transistor switching
threshold, but the workability would depend on the signal source
impedance and on the baud rate.
-- best regards
Tracy Allen
http://www.emesystems.com
mailto:tracy@e...
>Hi guys,
>Thanks in advace
>Col
knew one of you guys could help.
I do not have the device, nor do I have an oscilloscope. I am just
going off the minimal information I was able to get off the companies
web site. They have not answered my email querie as yet.
It is a super-hetrodyne receiver working at 433.92MHz. The only info
quoted is operating voltage (5v), current, frequency, sensitivity (-
105dBm), I.F. (270KHz), Max data rate (2KHz), max signal level that
can be decoded (-23.5dBm). (http://www.oatleyelectronics.com It is
their model RX14.)
I want to use it to send data between stamps, this module connected
via a stamp to a POS printer.
I may have to risk buying one to try it out. If the levels aren't
suitable then try your comparator solution. It's all good
experience :-)
Cheers
Col
--- In basicstamps@y..., Tracy Allen <tracy@e...> wrote:
> Those are very unusual levels. Do you actually have this device
oscilloscope?
feed
will
~1kohm
to
> -- best regards
> Tracy Allen
> mailto:tracy@e...
> >Hi guys,
BS2.
and a
min
(which I
> >Thanks in advace
> >Col
output of the receiver to the stamp that dropped the DC voltage
to 0
larry
Sent: September 12, 2002 7:53 AM
Subject: [noparse][[/noparse]basicstamps] Re: Serin question.
Thanks Tracy,
just
companies
info
that
is
their model RX14.)
connected
experience :-)
Cheers
Col
device
oscilloscope?
so
and
feed
signal
will
single
~1kohm
resistor
to
source
> -- best regards
> Tracy Allen
> mailto:tracy@e...
> >Hi guys,
the
BS2.
0.3V
and a
high
min
(which I
high
requires. If
modify
knowledgable as
> >Thanks in advace
> >Col
from the same email address that you subscribed. Text in the
Subject and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
output is inverted?
They are saying that a low is .7 * Vcc and a high is .3 * Vcc! So @5V
that means 0=3.5V and 1=1.5V. I suspect this is backwards. Also, usually
you'd specify your low as a MAX and your high as a MIN, so I'd be
willing to bet the MAX low is 1.5V and the MIN high is 3.5V.
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: aussiecol39 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=HOhumF7aIRlhbDcJmziiismps4gcz4fo0OLBcvfJRD7ULKRXgwsE5MUK0Wv2s3CV3UXfvIXE6zF8FDoBlHPe]aussiecol39@y...[/url
> Sent: Thursday, September 12, 2002 9:54 AM
> Thanks Tracy,
> sensitivity (- 105dBm), I.F. (270KHz), Max data rate (2KHz),
> their model RX14.)
> experience :-)
> Cheers
> Col
> oscilloscope?
> feed
> will
> ~1kohm
> to
> > -- best regards
> > Tracy Allen
> > mailto:tracy@e...
> > >Hi guys,
> BS2.
> and a
> min
> (which I
> requires. If
> reliably modify
> > >Thanks in advace
> > >Col
>Thanks Tracy,
>their model RX14.)
>experience :-)
>Cheers
>Col
Hi Col -
You may want to check out this link where a Stamp is used with that
same receiver:
http://www.scsoftware.com.au/family/andrew/camera/remote/mk1.shtml
Please note in the list of parts the non-catalog decoder from Oatley.
Bruce Bates
>oscilloscope?
>feed
>will
>~1kohm
>to
> > -- best regards
> > Tracy Allen
> > mailto:tracy@e...
> > >Hi guys,
>BS2.
>and a
>min
>(which I
> > >Thanks in advace
> > >Col
>from the same email address that you subscribed. Text in the Subject and
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
that all makes a lot of sense. I, in my ignorance, assumed it meant a
level of .7V not that it was .7 of the 5V. I feel a lot more
confident to pursue this now :-)
Thanks again.
Cheers
Col
--- In basicstamps@y..., "Al Williams" <alw@a...> wrote:
> This is almost surely a typo in the datasheet unless it is implying
the
> output is inverted?
@5V
usually
> Al Williams
> AWC
> > From: aussiecol39 [noparse][[/noparse]mailto:aussiecol39@y...]
> > To: basicstamps@y...
> > Thanks Tracy,
companies
info
is
> > their model RX14.)
connected
> > experience :-)
> > Cheers
> > Col
device
> > oscilloscope?
so
and
> > feed
> > will
single
> > ~1kohm
resistor
> > to
source
> > > -- best regards
> > > Tracy Allen
> > > mailto:tracy@e...
> > > >Hi guys,
> > BS2.
> > and a
high
> > min
> > (which I
high
> > requires. If
> > reliably modify
knowledgable as
> > > >Thanks in advace
> > > >Col
> > basicstamps-unsubscribe@y...
Thanks for that.
The link will be very useful to me not only for this project, but for
other ideas I have.
Cheers and thanks again.
Col
--- In basicstamps@y..., Bruce Bates <bvbates@u...> wrote:
> At 02:53 PM 9/12/2002 +0000, you wrote:
> >Thanks Tracy,
companies
info
> >their model RX14.)
> >experience :-)
> >Cheers
> >Col
> Hi Col -
> same receiver:
Oatley.
> Regards,
> Bruce Bates
> >oscilloscope?
so
> >feed
> >will
> >~1kohm
resistor
> >to
> > > -- best regards
> > > Tracy Allen
> > > mailto:tracy@e...
> > > >Hi guys,
> >BS2.
> >and a
high
> >min
> >(which I
high
requires. If
modify
knowledgable as
> > > >Thanks in advace
> > > >Col
Subject and
could be an option. Still, I think I need an oscilloscope to sus out
exactly what the outputs are :-)
Cheers
Col
--- In basicstamps@y..., "Larry Gaminde" <lgaminde@t...> wrote:
> What I did on my rf receiver is use a .01 or .1 cap from the
> to 0
> larry
> From: "aussiecol39" <aussiecol39@y...>
> To: <basicstamps@y...>
> Thanks Tracy,
> just
> companies
> info
> that
> is
> their model RX14.)
> connected
> experience :-)
> Cheers
> Col
> device
> oscilloscope?
> so
> and
> feed
> signal
> will
> single
> ~1kohm
> resistor
> to
> source
> > -- best regards
> > Tracy Allen
> > mailto:tracy@e...
> > >Hi guys,
> the
> BS2.
> 0.3V
> and a
> high
> min
> (which I
> high
> requires. If
> modify
> knowledgable as
> > >Thanks in advace
> > >Col
