Two Questions...
HELP!
Hi Everybody,
I need your help with a BS2 project. I have two(maybe three)
strobes that I'd like to digitally trigger alternately. When a positive
pulse arrives, I'd like the first strobe to fire, on the next pulse I'd
like the second to fire and on the next pulse, fire the first strobe again
- just alternate back and forth between strobes. I thought that this would
be simple enough to do using a flip-flop, but all the circuits and
information that I find don't quite fit this situation and I've never used
flip-flops before which doesn't help. There are so many different
types. I'M SURE THAT I'M MAKING THIS MUCH MORE COMPLICATED THAN IT NEEDS
TO BE!! How would you go about it?
Also, I have a photo emitter/detector pair that I'd like to get a
nice square signal out of, instead of the varying voltage dependant upon
the reflection that it sees. Is this an application for a schmitt trigger?
Please help a rookie learn.
Tim
Timothy Medema
CrystaLite, Incorporated
3307 Cedar St. (425) 745-6000 800-666-6065
Everett, WA 98201 Fax: (425) 257-0232
www.crystaliteinc.com
<mailto:timm@c...>timm@c...
The information transmitted is intended only for the person or entity to
whom it is addressed and may contain confidential and/or privileged
material. Any review, retransmission, dissemination or other use of, or
taking of any action in reliance upon, this information by persons or
entities other than the intended recipient is prohibited. If you received
this in error, please contact the sender and delete the material from any
computer.
Hi Everybody,
Tim
Timothy Medema
computer.
switches for you.
There is a flashing LED program on the Parallax site that can help you set
the correct pins
to high and low.
Timothy Medema <timm@c...> on 09/09/2002 04:03:59 PM
Please respond to basicstamps@yahoogroups.com
cc:
Subject: [noparse][[/noparse]basicstamps] Two Questions...
HELP!
Hi Everybody,
Tim
Timothy Medema
computer.
through the BS2, rather it's a sub-circuit with the trigger logic pulse
train coming into it.
Tim
At 04:17 PM 9/9/2002 -0500, you wrote:
>I would personally use 2 pnp MOSFET's that would behave like digital
>switches for you.
>the correct pins
>to high and low.
>cc:
>HELP!
>Hi Everybody,
>Thanks,
>Tim
>Timothy Medema
>computer.
can send them a high or low signal.
Timothy Medema <timm@c...> on 09/09/2002 04:34:39 PM
cc:
Subject: Re: [noparse][[/noparse]basicstamps] Two Questions...
Thanks for the information, but I'm not controlling the strobes directly
Tim
>switches for you.
>the correct pins
>to high and low.
>cc:
>HELP!
>Hi Everybody,
would
a
trigger?
>Thanks,
>Tim
>Timothy Medema
>computer.
Thank you very much - I'll take a look,
Tim
At 04:53 PM 9/9/2002 -0500, you wrote:
>Using two mosfets will still work with any kind of circuit as long as you
>cc:
>Tim
> >switches for you.
> >the correct pins
> >to high and low.
> >cc:
> >HELP!
> >Hi Everybody,
>would
>a
>trigger?
> >Thanks,
> >Tim
> >Timothy Medema
> >computer.
mode:
Tie pins J and K High, your trigger goes to the CLK input.
The outputs Q and Q-not will alternate high with each clock pulse.
A simple one is the 74LS73 which is a dual J-K, though not sure if it
is positive or negtive triggered. Also, you'll need to tie the Clear
pin to the non-clear state.
As far as cleaning your IR output, you can use simple op-amp, such as
the LM358. Configure in a comparator mode where the - or inverting
input is the middle of your voltage swing, and your signal enters the
+ or non-inverting input. This will give you a clean TTL out.
Our Industrial Control text from Parallax has a chapter on signal
conditioning just what you are talking about.
http://www.stampsinclass.com/html_files/sic_curr/curriculum_industrial
.asp
Good luck!
Martin Hebel
BASIC Stamp Tutorial on-line at:
http://imsinet.casa.siu.edu/bs2_tutorial/
Southern Illinois University
Electronic Systems Technology
--- In basicstamps@y..., Timothy Medema <timm@c...> wrote:
> HELP!
> Hi Everybody,
three)
positive
I'd
strobe again
this would
never used
NEEDS
to get a
upon
trigger?
> Thanks,
> Tim
> Timothy Medema
entity to
of, or
received
from any
> computer.
so easy.
Very much appreciated,
Tim
At 06:44 PM 9/10/2002 +0000, you wrote:
>As far as Flip-Flops, you can use a simple J-K Flip flop in toggle
>mode:
>.asp
>Good luck!
>Martin Hebel
> > HELP!
> > Hi Everybody,
>three)
>positive
>I'd
>strobe again
>this would
>never used
>NEEDS
>to get a
>upon
>trigger?
> > Thanks,
> > Tim
> > Timothy Medema
>entity to
>of, or
>or
>received
>from any
> > computer.
