auto-reset?
I'm powering a 7-segment display with my basic stamp (the type of
display that takes 7 pins on my basic stamp, because im not using a
driver). So I run vdd to the power pin on the display, then attach
all 7 led pins to pins 0 - 6 on my basic stamp. Then I write a
program that sets all those pins to low output.
It works like it should, but every so often the display (and main
power light on the boe) flash off and on really quickly... why is
this? My guess is that for some reason the stamp is auto-resetting
itself... am i sinking too much current with my stamp?
Thanks for the help
Greg
Thanks for the help
Greg
If not you are probably overloading the power supply and it is shutting down
due to overload.
Eric
Sent: Friday, September 06, 2002 4:59 PM
Subject: [noparse][[/noparse]basicstamps] auto-reset?
> Thanks for the help
> Greg
pin. I have no resisters between the grounded pins and the stamp's
outputs... is this bad? That would be a lot of resistors...
thanks
Greg
--- In basicstamps@y..., "Eric Adams" <hugs102@b...> wrote:
> You didn't mention a current limiting resistors at all. Are you
using them?
shutting down
> due to overload.
> Eric
> From: "GregT2" <gregt@t...>
> To: <basicstamps@y...>
a
> > Thanks for the help
> > Greg
> > basicstamps-unsubscribe@y...
Subject and
