Radio shack IR
I have a RadioShack (cat # 275-142) IR emitter and detector... And
i've got no idea how to use them with my basic stamp.
Im quite sure that it's a analog detector (like a normal photocell..)
could someone please explain how to detect IR using this
emitter/detector? Is it possible to modulate it so I don't get false
readings from other IR sources nearby?
Any help would be appricated, I'm not to great with basic electronics.
Greg
Greg
gregt@t... writes:
Go to www.parallaxinc.com , click on downloads, and download their
documention on using IR. Complete with code.
Sid
this schematic (All pin# are according to BASIC Stamp 2):
I/O Pin>----(IR)
|-|- Ground
Connect a detector like this:
I/O Pin>----(DET)
|-|- Ground
You need an ambiant light filter to filter out ambient rays of IR. You can get
one from Radio Shack (included in RS# 270-215, a project case/membrane keypad
set, it includes a red piece of plastic, that is the filter.). Place the
detector in the case and put the filter over it. Use the following PBASIC code
(for BS2) to detect IR:
input #
if in# = 0 then yes
replace # with the pin number and yes with the label you wish to go to if there
is ir on the detector.
To send IR you would use:
HIGH #
Replace # with I/O pin number. A little more code would allow you to
send/recieve data using Binary and Infrared!
Hope this helps you!
--Jake
Sent: Thursday, September 05, 2002 6:24 PM
Subject: [noparse][[/noparse]basicstamps] Radio shack IR
> Thanks
> Greg
need a filter because (your right) in any sort of light, the IR isn't
even noticably visable.
Greg
--- In basicstamps@y..., "Jacob Rossi" <coolnetdude@c...> wrote:
> I have the same emitter/detector. What you need is to connect the
emitter using this schematic (All pin# are according to BASIC Stamp
2):
> I/O Pin>----(IR)
|-|- Ground
> I/O Pin>----(DET)
|-|- Ground
You can get one from Radio Shack (included in RS# 270-215, a project
case/membrane keypad set, it includes a red piece of plastic, that is
the filter.). Place the detector in the case and put the filter over
it. Use the following PBASIC code (for BS2) to detect IR:
> input #
> if in# = 0 then yes
to if there is ir on the detector.
> HIGH #
to send/recieve data using Binary and Infrared!
> --Jake
> From: "GregT2" <gregt@t...>
> To: <basicstamps@y...>
And
photocell..)
false
electronics.
> > Thanks
> > Greg
> > basicstamps-unsubscribe@y...
Subject and Body of the message will be ignored.
strengthen the signal:
Sample IR recieving circuit that turns a LED on when IR is revieved:
________________
-3V+ | /
|-|-|--|-(DET)
(NPN)
|___________(LED)___~650~______|
The DET is the detector NPN is a NPN transistor. It is oriented as follows:
/---Emitter
BASE
(NPN)
\----Drain
Try this out
Sent: Sunday, September 08, 2002 4:44 PM
Subject: [noparse][[/noparse]basicstamps] Re: Radio shack IR
> I actually got it working with rctime... like a photocell, but I do
> Greg
> 2):
> > I/O Pin>----(IR)
|-|- Ground
> > I/O Pin>----(DET)
|-|- Ground
> > input #
> > if in# = 0 then yes
> > HIGH #
> > --Jake
> And
> photocell..)
> false
> electronics.
> > > Thanks
> > > Greg
