Serial programing cable
My project requires that my BS2P40 be mounted inside a cabinet. I
would like to permanently wire the serial programming pins (1-4) to
an external serial plug that I can plug into to program the BS2P40,
without opening the cabinet to connect the programming cable. I have
the external plug and everything works fine as long as the PC is
attached through the external serial plug. But when I disconnect the
serial cable, my LCD display becomes scrambled. Do I need to
terminate the connections in the serial plug someway when it is not
connected to the computer? Does anyone have any suggestions as to
what is happening?
what is happening?
