Water show, (was sprinkler system wiring) — Parallax Forums
edited 2002-09-04 16:08 in General Discussion
Actually that IS a great idea! Has anyone done this? Where would one find
cheap water shut-off solenoids?
| | dg@d...|
| | om |
| | 09/03/2002 04:09|
| | PM |
| | Please respond |
| | to basicstamps |
| To: basicstamps@yahoogroups.com
| cc:
| Subject: [noparse][[/noparse]basicstamps] Re: sprinkler system wiring
Ever since my wife saw the water show at the Bellagio she's wanted
one of those for the front yard. I'll post a question later about how
to program a stamp to do that!
    edited 2002-09-04 01:40
    Cheap ? probably not.
    WWW.Graniger would carry some styles.
    one could probably use sprinlkler valves, about 10 bux each, probably
    less in any quantity.
    for the scrounger, discarded washing machines typically have a good
    one in them, 110 VAC. usually on a seperate panel so it would be
    rather easy to remove at the curb.
    One problem is that you need a large opening so it need to be about
    the size of a garden hose.
    Dave
    one find
    > | | dg@d...|
    > | | om |
    > | | 09/03/2002 04:09|
    > | | PM |
    > | | Please respond |
    > | | to basicstamps |
    > | To:
    basicstamps@y...
    cc:
    wiring
    how
    edited 2002-09-04 13:16
    To find cheap industrial quality solenoids try www.valvestore.com . Average
    price is $45-60 for 1/4 NPT Valves.
    I suspect the big water shows use air assisted water supplies. The power
    needed to shoot the large volume of water into the air most likely comes from
    a large industrial type air compressor. That is the economical way to
    overcome the problems of rapid firing 25 pound bursts of water (1 gallon = 8
    pounds) into the air. Remember this is high pressure AND high volume. Lots of
    mass to accelerate against gravity in an upward direction. Most commercial
    pumps are high pressure or high volume.
    The domestic water supply is usually fed into your house through a 1" or
    smaller pipe. This limits the size of your show, but is a cheap way to start.
    A larger show could be used with a pool of water and a pump. This is a larger
    initial investment, but easier on the H2O Bill.
    The solenoids will need to be as close to the nozzles as possible to get the
    best turn on and off times. If the valves are far away then the pressure in
    the hoses need time to built up and bleed off. This would most likely look
    like a wimpy slow building jet and gradually bleed off. The elasticity of the
    hose makes this problem worse. That is why the hose runs for a few seconds
    after you turn off the faucet.
    I am not an expert on this, but I saw the show at Epcot 5 years ago and
    "wanted one for the front yard" also. The idea got shot down fast when the
    power company refused to give me a 3 phase electric service for the
    compressor. (PS the Boss shot down the idea sooner.) I have just diverted
    lots of idle time 'Mental Energy' into this gadget.
    The sequencer is the easy part. I use a Stamp2 in a 16 channel ILC
    (Industrial Logic Controller) in my plasma cutting machines. The ILC uses all
    16 I/O pins on the stamp and runs Opto 22 type Solid State I/O modules. You
    can put 16 AC output modules and run 16 ac solenoids. The ILC costs $250 and
    the I/O modules are about $12-15 each. Its expensive, but it works and the
    I/O modules handle all the switching transients. I use these to run AC valves
    with Oxygen, Air, Fuel Gas and Inert Gasses without a single failure in
    almost 8 years. Cheapest isn't always cheapest. A shorted output means the
    water runs all the time. This needs to be addressed as it could get
    expensive. Especially if you flood the neighbors basement.
    AC Solenoids are easier to use and do not require a separate power supply.
    Proper grounding is necessary and use a ground fault type AC power source. A
    DC Power supply would be safer to use, but the power supply adds cost and DC
    Solenoid valves are a little more money then AC ones.
    This should get you started with a small lawn sized project.
    Alan Bradford
    Plasma Technologies
    edited 2002-09-04 14:06
    air-over-water would consume a lot of air to get a
    little water flying, it's probably not practical. Air
    is very expensive. I might think hydraulics . . .
    i.e., pump water into an accumulator, use dump valves
    to make the water fly. That's probably why they are
    intermittent, i.e., you need time to fill the
    accumulator (the pump is lower volume at high
    pressure, the valves empty out the accumulator faster
    than the pump can fill it).
    great group, got my BS2 hooked up to my Tek922, go the
    serial thing going with a DOS laptop, led's blinking,
    etc. Thanks to all.
    > supplies. The power
    > economical way to
    > service for the
    > 16 channel ILC
    > a single failure in
    > as it could get
    > basement.
    > ones.
    > project.
    > Alan Bradford
    > Plasma Technologies
    > from the same email address that you subscribed.
    > Text in the Subject and Body of the message will be
    > ignored.
    __________________________________________________
    Do You Yahoo!?
    Yahoo! Finance - Get real-time stock quotes
    http://finance.yahoo.com
    edited 2002-09-04 15:41
    As cool as it would be to have a solid pulse of 1" dia. water jump out of
    the floor, I guess I was looking for something to 'play' with. I saw a
    table top model that had 20 or more 'squirts' of water that sequenced with
    music at Walmart for about $100. I was just looking for the source of the
    water valves. I saw something on Discovery that showed the $$$ and
    componentry it takes just to create a solid stream of water. : o
    edited 2002-09-04 15:50
    Just to add my two cents into the mix. I have been
    involved in several large scale fire and water shows
    where heavy duty ALLEN BRADLEY DC PLC motor
    controllers and heavy duty (emphasis on heavy) DC
    motors with impeller pumps attached are used to
    acheive maximum velocity and distance in as little as
    two seconds. With the delays factored into the program
    and the correct nozzles one can easily make jets and
    spouts of water as high as 20 or more feet appear
    almost instantly.
    Chuck
    Do You Yahoo!?
    edited 2002-09-04 15:59
    Chances are it worked with a mechanical rotary valve and / or a disk with
    holes in it. Very unlikely they had 20 valves in there.
    I actually like the fountains near the Westward Ho myself. Little squirts of
    water arc between fountains on the sidewalk. They maintain a fairly decent
    cylinder shape and look neat going through the air.
    In a message dated 9/4/02 10:04:28 AM Central Daylight Time,
    daweasel@s... writes:
    The "shape" is caused by the use of stream straighteners in the nozzles.
    I've heard of home-built fountains creators that have embedded a bunch of
    common soda straws in their nozzles to get this effects. The idea is to
    restore laminar flow to the water before it leaves the nozzle.
