I2C N&Volts 8/02 — Parallax Forums
I2C N&Volts 8/02
edited 2002-08-30 08:06 in General Discussion
Why didn't they use the I2C commands to do the EEPROM
communications. Is this because these statements are not available
on the BS2, or is you approach more efficient for other reasons.
thanks
    edited 2002-08-29 21:15
    Speaking of I2C and EEPROMs, I have had some success with this recently, on
    a BS2.
    For those interested, I have successfully bit bashed I2C on a BS2 (which
    doesn't have built in I2C commands, like the BS2p).
    I've managed to write to, and read from, a 24LC02 2kb EEPROM.
    Details are at http://www.lennard.net.nz/ click on Circuit Ideas, then
    select I2C.
    The page is still being constructed, and I will hopefully add the code to
    the page by the end of today (NZ time).
    cheers,
    Ben.
    Ben Lennard, NCEE, Dip EE
    Web Hosting and Electronics R&D
    Hm: +64 4 972 7567
    Mb: +64 21 536 627
    87 Spencer Street
    Crofton Downs
    Wellington
    New Zealand
    "To the optimist, the glass is half full. To the pessimist, the glass is
    half empty. To the engineer, the glass is twice as big as it needs to be."
    No animals were harmed in the transmission of this email, although the
    Dog next door is living on borrowed time, let me tell you! Those of you
    with an overwhelming fear of the unknown will be gratified to learn that
    there is no hidden message revealed by reading this warning backwards.
    > From: "lightningshack" <MikDolan54@a...>
    > Reply-To: basicstamps@yahoogroups.com
    > Date: Thu, 29 Aug 2002 19:55:05 -0000
    > Subject: [noparse][[/noparse]basicstamps] I2C N&Volts 8/02
    > thanks
    > Mike
    > of the message will be ignored.
    edited 2002-08-29 22:40
    I2CIN and I2COUT are only availble on the BS2p. The article demonstrates the
    use of I2C on the other BS2 series BASIC Stamps.
    -- Jon Williams
    In a message dated 8/29/02 3:11:53 PM Central Daylight Time,
    MikDolan54@a... writes:
    Hi all,
    Interesting timing this...
    I haven't even read the article in Nuts and Volts on I2C on a BS2, and have
    come up with my own solution.
    The code is now on my web site http://www.lennard.net.nz/
    Click on circuit ideas, then I2C.
    Will be interesting to see the differences in the Nuts and Volts article and
    how I did it. N & V probably better, considering somewhat of a difference
    in experience... :-)
    I can see I2C being very useful in freeing up more pins. Example, I will be
    working on getting an HD44780 based LCD display down to only 4 pins needed
    to connect to the BS2 (5 if you need to control RW), using a PCF8574 I2C to
    Parallel port IC.
    Cheers,
    Ben, Windy Wellington, New Zealand.
    Hm: +64 4 972 7567
    Mb: +64 21 536 627
    87 Spencer Street
    Crofton Downs
    Wellington
    New Zealand
    > From: Ben <ben@l...>
    > Date: Fri, 30 Aug 2002 08:15:41 +1200
    > To: <basicstamps@yahoogroups.com>
    > Subject: Re: [noparse][[/noparse]basicstamps] I2C N&Volts 8/02
    > a BS2.
    > select I2C.
    > cheers,
    > Ben.
    > Hm: +64 4 972 7567
    > Mb: +64 21 536 627
    > 87 Spencer Street
    > Crofton Downs
    > Wellington
    > New Zealand
    >> thanks
    >> Mike
    >> Body
