Help wanted to implement a switch in my code
Hi..
I am a newcomer and I need starting help.
Can anybody show me how I imlement three pushbuttons in my code?
Like this:
First pushbutton:
(to step thru the colours)
Push 1 = red only
Push 2 = red and green only
Push 3 = green only
Push 4 = green and blue only
Push 5 = blue only
Push 6 = red and blue only
Push 7 = start the sequenz
Push 8 = off
Second pushbutton: (changed the worth named "a")
Push = Speed up
Third pushbutton: (changed the worth named "a")
Push = speed down
And this is my code:
cut
' Changes the brightness of LED`s using PWM
' {$STAMP BS2}
Pin0 CON 0 'LED red
Pin1 CON 1 'LED green
Pin2 CON 2 'LED blue
level VAR Byte
a VAR Byte
DlyTm CON 0 'Pause
a = 1 'Steps
Main:
High Pin0 'LED red on / red on
Low Pin1 'LED green off
Low Pin2 'LED blue off
Loop:
FOR level = 0 TO 255 Step a 'LED green up / red and green on
PWM Pin1,level,25
PAUSE DlyTm
NEXT
FOR level = 255 TO 0 Step a 'LED red down / green on
PWM Pin0,level,25
PAUSE DlyTm
NEXT
Low Pin0 'LED red off
FOR level = 0 TO 255 Step a 'LED blue up / green and blue on
PWM Pin2,level,25
PAUSE DlyTm
NEXT
FOR level = 255 TO 0 Step a 'LED green down / blue on
PWM Pin1,level,25
PAUSE DlyTm
NEXT
FOR level = 0 TO 255 Step a 'LED red up / blue and red on
PWM Pin0,level,25
PAUSE DlyTm
NEXT
FOR level = 255 TO 0 Step a 'LED blue down / red on
PWM Pin2,level,25
PAUSE DlyTm
NEXT
GOTO Loop
END
cut
Thanks for help.
Best regards, Kai
Like this:
First pushbutton:
Push 1 = red only
Push 3 = green only
Push 5 = blue only
Push 8 = off
Push = Speed up
Push = speed down
cut
' {$STAMP BS2}
Pin0 CON 0 'LED red
level VAR Byte
a VAR Byte
DlyTm CON 0 'Pause
a = 1 'Steps
Main:
Loop:
PWM Pin1,level,25
PAUSE DlyTm
NEXT
PWM Pin0,level,25
PAUSE DlyTm
NEXT
PWM Pin2,level,25
PAUSE DlyTm
NEXT
PWM Pin1,level,25
PAUSE DlyTm
NEXT
PWM Pin0,level,25
PAUSE DlyTm
NEXT
PWM Pin2,level,25
PAUSE DlyTm
NEXT
GOTO Loop
END
cut
Thanks for help.
Best regards, Kai
