BS2 BS2P first steps
Hello,
I'm using a BS2 to control a mini sscII servo controller.
When I put on the socket a BS2 the servo attached to the
minicontroller is working properly.
But when I replace the BS2 by the BS2P on the socket, the green led
on the mini sscII remains always green. And nothing happens when a
command is sent from the BS2P to the mini sscII. The servo doesn't
move. The only think change is the Basic Stamp on the socket.
Is the code different between the BS2 and BS2P ?
Thanks for your help.
This is the code :
'{$STAMP BS2p}
svo con 0 'use servo 0
sync con 255 'Mini SSC sync byte
pos var byte 'Byte variable holds position value
BtnWrk var byte
x var byte
n96n con $4054
pos = 165:serout 10,n96n,[noparse][[/noparse]sync,svo,pos]
pause 1000
pos = 2:serout 10,n96n,[noparse][[/noparse]sync,svo,pos]
This is the code :
'{$STAMP BS2p}
BtnWrk var byte
x var byte
n96n con $4054
pause 1000
n96n con $4054
to
n96n con $40f0
That should fix it, or at least its a start.
Sent: Tuesday, August 27, 2002 3:58 PM
Subject: [noparse][[/noparse]basicstamps] BS2 BS2P first steps
> Hello,
> This is the code :
> '{$STAMP BS2p}
> BtnWrk var byte
> x var byte
> n96n con $4054
> pause 1000
