circuit diagramming software — Parallax Forums
edited 2002-08-26 18:57 in General Discussion
Does anyone know of a low-cost (or free) circuit diagramming
software? Also, a low-cost circuit board etching software? Thanks.
Scott
    edited 2002-08-23 20:32
    There are a few sites on the web that take your dsign files
    and generate a quick turn PCB. Some also supply the needed
    software. For example, check out:
    http://www.expresspcb.com/
    They offer design software which can then feed your layout
    to them for manufacturing. This is a bit of a "captive
    marketing" approach, but they do both design and board
    layout and their boards are cheap.
    If these guys don't excit, do a google search as there are
    others with similar offerings...
    - peterd
    Peter Deutsch pdeutsch@g...
    Gydig Software
    Alcohol and calculus don't mix, so never
    drink and derive...
    edited 2002-08-23 20:42
    Scott,
    Similar to expresspcb, I use pcb123. The schematic and layout
    software is free. Basically, just design your circuit with their
    schematic application and then the layout application will place the
    components on your board and you can perform an autoroute and it will
    layout the traces. Then you upload the layout files to them and they
    will manufacture your boards and send them to you. One of the coolest
    items is their layout software continually updates the price of your
    board as you go along. I think their prices are pretty reasonable. My
    first project took me a weekend to learn their software through
    designing my custom parts, creating my schematic, performing the
    layout, move my parts around the board and finish the project. I
    ordered my boards from them Monday morning and they were shipped out
    to me that same afternoon. Check them out at www.pcb123.com.
    Guy
    MB Digital Interiors
    > Scott
    In a message dated 08/23/2002 14:57:53 Eastern Daylight Time,
    Scott@b... writes:
    Try www.expresspcb.com for free program.
    There is no such thing as "etching" software. There is routing and machining
    software, but that is a different story.
    Sid
    edited 2002-08-23 20:54
    Hi Scott,
    I use the Eagle free edition, which has some limitations :
    The following limitations apply to the EAGLE Light Edition in general:
    The useable board area is limited to 100 x 80 mm (4 x 3.2 inches).
    Only two signal layers can be used (Top and Bottom).
    The schematic editor can only create one sheet.
    Apart from these three limitiations the EAGLE Light Edition can do
    anything the Professional Edition can do. You can even load, view and
    print drawings that exceed these limits!
    The Freeware version of EAGLE Light adds these limitations:
    Support is only available via email or through our forum (no fax or
    phone support).
    Use is limited to non-profit applications or evaluation purposes.
    It's a fully functionnal software, for schematic capture and pcb
    design, with autorouting and *many* libraries.
    Have a look on www.cadsoft.de
    Phil.
    Sent: Friday, August 23, 2002 8:57 PM
    Subject: [noparse][[/noparse]basicstamps] circuit diagramming software
    | Scott
    edited 2002-08-24 15:35
    Hey,
    I'm looking for a circuit diagramming software that will import an OrCAD
    design and lay it out on a PCB board for me. I don't need the company to
    manufacture it for me...I enjoy doing it the old-fashion way with etchant.
    Thanks.
    Matt
    From: southernpost [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mp_BwnClCTuoRL58JYuBylgzIakifxAXzTlx3BKrjFyefZY9yis7XJSYbsVhsjx6lcZhZIqSefwGuvelhj8]Scott@b...[/url
    Sent: Friday, August 23, 2002 1:57 PM
    Scott
    edited 2002-08-26 00:25
    Hi Scott,
    I've been looking for the same thing, and I found TRAXMAKER trial,
    but its limitation is you can't creat components, but other wize its a
    beauty,
    regards Gary
    From: southernpost [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=bjYY2hb2m2JYY1C7HcB9aooByXMRQpnqaJC_ilSA3umoXTmCgpqz1_XYF-AqHP6pUMexwoL9RBwjXB63ZJBiAWYW]Scott@b...[/url
    Sent: Saturday, 24 August 2002 2:57 AM
    Scott
    edited 2002-08-26 02:18
    Scott;
    I use a program called Electronic Workbench from Interactive Image Technologies.
    http://www.interactiv.com/
    I use it for electronic circuit simulation. I have used versions of it for
    about 10 years and it works amazingly
    well. It is a little pricey costing hundreds of dollars. I know they do offer
    a program that will do a circuit
    board layout from a schematic diagram. I suspect it might be pricey as well. I
    don't know what you mean by
    low-cost. Anyway you might give them a look.
    Good luck,
    Jim
    gracesmith wrote:
    > Hi Scott,
    > beauty,
    > regards Gary
    > From: southernpost [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0r9RbblNYXg1aBNAFe0rcY2vGkSmSxHXuz8RPCIfn1ch8gDjDkdlMoET-Ya8CDHWA_wIRM86oyIe-L-FBiMKGx4]Scott@b...[/url
    > Scott
    edited 2002-08-26 04:34
    Scott,
    I also use Multisim and Ultiboard, if by chance you are a student you can get a
    pretty good deal on it. I think it costed me 100 dollars for each program. Even
    the standard hobby edition is only 299 or so which by itself is expensive but
    compared to other eda's like protel dxp $8000 or orCAD $14,000 or any other
    proffessional eda that can do an equivalent spice 3f5 mixed signal simulation is
    pretty darn cheap!
    Jim Beeson wrote:Scott;
    I use it for electronic circuit simulation. I have used versions of it for about
    well. It is a little pricey costing hundreds of dollars. I know they do offer a
    Good luck,
    Jim
    gracesmith wrote:
    > Hi Scott,
    > beauty,
    > regards Gary
    > From: southernpost [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tKGsAworll9qjOeXmuFn0CA0Go4OMIHiDfY-1FeqJGBSlHkx8lMpiaWZMaYgJUkCnAPt4k2JXNKlYHROOZNj5Q]Scott@b...[/url
    > Scott
    from the same email address that you subscribed. Text in the Subject and Body of
    Do You Yahoo!?
    Yahoo! Finance - Get real-time stock quotes
    edited 2002-08-26 16:48
    Go to http://www.ivex.com/
    You can use ivex windraft to draw a schematic and then you export
    it into a netlist and use winboard to design your circuit board. I
    have found you can get lower pin versions from local supply
    houses(lower price) The software manufacturer seems to have
    been around for quite awhile. Their technical support from my
    experience is quite good also.
    Expresspcb.com used to have a free download of their design
    software. You can't get rid of the dots on the printout though.
    Mark
    edited 2002-08-26 17:08
    In my opinion Ivex sucks!!!! It is always freezes with Windows 2000, IVEX PCB
    doesn't even work on the WINXP platform. If it happens to freeze while you are
    saving your work so don't expect to open the file as it will be corrupted. IVEX
    PCB can not autoroute either. I would stick with eagle for schematic capture and
    pcb layout and camtastic for post processing.
    Good Luck!
    -=Randy Knutson
    mwaddell@s... wrote:Go to http://www.ivex.com/
    Mark
    Do You Yahoo!?
    edited 2002-08-26 18:20
    I have never tried it on anything but 95 and 98. Sorry for the bad
    experience.
    Mark
    I've found WinBoard (Ivex) to be robust and reliable on Windows 2000.
    Earlier program freezes on Win 95 and 98 were usually due to bad
    techniques on my part using netlists and ground planes. When that
    happened, Ivex tech support responded promptly, sometimes requesting my
    board file by email to recover it. Sure, WinBoard has limitations, but
    so does most software, so evaluating tech support response should be
    part of the equation.
    FWIW, I first learned programming on a Univac I, a vacuum tube machine.
    At any given time, about 200 tubes would blow, so my program never
    produced the same results twice in a row. I'm therefore more tolerant
    than most of software bugs, except my own of course.
    Dennis
    From: Randy Knutson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=EGs-GncbAsiAg_Wx6v6RG25s9nOW3YiO4K2EsHbP_dIrCEEMpWKszZO1xPu-ptCnR8x21_0w5XKhrau4hA]ken_ryder@y...[/url
    Sent: Monday, August 26, 2002 9:09 AM
    Subject: Re: [noparse][[/noparse]basicstamps] circuit diagramming software
    IVEX PCB doesn't even work on the WINXP platform. If it happens to
    freeze while you are saving your work so don't expect to open the file
    as it will be corrupted. IVEX PCB can not autoroute either. I would
    stick with eagle for schematic capture and pcb layout and camtastic for
    post processing.
    Good Luck!
    -=Randy Knutson
    Do You Yahoo!?
