Max7219 8-digit display driver
I am planning to make a counter incorporating a MAX7219 8-digit
display driver. I have looked at some of the BS2 code and the MAX7219
data sheet. I am getting ready to start. However, I have selected a
1" seven segment common cathode LED (I'll use 8 of these) but I am
not quite sure if i need external drivers for the LEDS or if the
MAX7219 can handle the displays without.
Any suggestions?
Guy
Any suggestions?
Guy
won't have any problems. There is a current limiter in the circuit. You can
always adjust that if you need to for your specific displays.
-- Jon Williams
In a message dated 8/13/02 11:31:49 PM Central Daylight Time,
guyb@m... writes:
> Any suggestions?
> Thanks,
sheet and BS2 code examples to process & display only one digit at a
time, but to display multiple digit results as required e.g.
display "1234" and no leading zeros. I think I might be OK on the
device that I selected since the typ forward voltage is 3.4V and the
typ forward current is 10mA.
What are your thoughts?
Guy
--- In basicstamps@y..., jonwms@a... wrote:
> Since the MAX7219 is a multiplexer [noparse][[/noparse]only one digit is lit at a
time], you
circuit. You can
> -- Jon Williams
> guyb@m... writes:
MAX7219
a
am
> > Any suggestions?
> > Thanks,
