BS2p Math
I am reading a 12 bit A/D that is connected to a pressure sensor that
is trimmed up to 2.5V so that I can measure vacuum.
The pressure sensor outputs 150 mV/PSI and I want to then convert
this to inches of Hg which 1 PSI = 2.036021 inHg.
Right now I can zero out the reading by:
Zero = 2500 - CH_0
Which is a no brainer but ,
PSI = Zero/150
just gives me a whole number thats rounded off???
Once I have this PSI converson done I think I can convert to inHg
with this:
inHg = (PSI * 2) + (PSI ** 2361)
Need help with division.
Jason
Zero = 2500 - CH_0
PSI = Zero/150
with this:
Jason
If I take (Zero * 10)/15 then I get an acceptable amount of
resolution.
Unless any of you out there have a better way to do it.
Jason
that
> Zero = 2500 - CH_0
> PSI = Zero/150
> with this:
> Jason
I see you answered your own question. Here is another way to do it,
by working with the remainder from the first division:
PSI = ch_0/150*100 + (ch_0//150*100/150) - 1666
1st division remainder division offset
example, when ch_0=1234 then PSI= -844 to represent -8.44.
Note that division on the Stamp does not work right on negative
numbers, so if negative numbers might turn up, I always subtract the
offset _after_ doing the division. Your result ch_0 I think is
positive from the 12 bit A/D. 1666=2500/150*100 precalculated.
You trick for division is fine, using 15 instead of 150. The only
advantage of the "remainder" method above would come if your scale
factor happened to be, say, 153 instead of 150.
I hope that helps!
-- regards,
Tracy Allen
mailto:tracy@e...
http://www.emesystems.com
>You have to excuse my previous brain fart.
>resolution.
>Jason
>that
> > Zero = 2500 - CH_0
> > PSI = Zero/150
> > with this:
> > Jason
