ECG ICs
Hi all,
I've got some ICs with ECGxxxx part number.
Is there a website where I could find the *datasheet* of those components ?
I've found differents sites with the description of the functions (like
'quad nand gate' or something else...), but I need more than that.
Sorry for this OT question, and thanks for your help !
Phil.
Phil.
>Hi all,
>Phil.
>Phil -
Could you offer a typical entire part number ? "ECG" alone isn't quite
enough to give you a firm answer.
Bruce Bates
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
I agree, knowing the actual numbers would help. NTE
electronics took over ECG some time ago. You could
search their cross-reference data base at
www.nteinc.com but be aware that certain common series
ic's (like 7400 series) do not have data sheets
listed. I have several older ECG catalogs that I couls
look up info if you could post the numbers.
Chuck
--- Philippe Derenne <derennep@b...> wrote:
> Hi all,
> the functions (like
> more than that.
> Phil.
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do You Yahoo!?
HotJobs - Search Thousands of New Jobs
http://www.hotjobs.com
ECG and NTE part numbers are directly compatible. Take a look a
www.nteinc.com and plug in your ECG part number, then you will get the
equivalent of data sheet information.
Tim
At 11:06 AM 8/13/2002 +0200, you wrote:
>Hi all,
>Phil.
I've been on www.nteinc.com, but I can't find the information I want.
The IC I have are ECG9332 and ECG9383.
The 9332 must be a "quad inverter and dual 2-input nand gate open
collector".
The 9383 must be a "BCD to 7-segment decoder/driver open collector".
I've got this information from a cross-ref index found on the net. All I
need now is at least the pinout of those ICs.
Thank for your answer !
Phil.
Sent: Tuesday, August 13, 2002 2:27 PM
Subject: Re: [noparse][[/noparse]basicstamps] ECG ICs
> Greetings,
> Chuck
> > Hi all,
> > the functions (like
> > more than that.
> > Phil.
You are correct with the names. Pinouts are as
follows. (I hope this isn't confusing!!)
ECG9332
1 A5 NAND IN 9 O2 Hex OUT
2 B5 NAND IN 10 A2 Hex IN
3 O5 NAND OUT 11 O4 Hex OUT
4 A3 Hex IN 12 A4 Hex IN
5 O3 Hex OUT 13 O6 NAND OUT
6 A1 Hex IN 14 A6 NAND IN
7 O1 Hex OUT 15 B6 NAND IN
8 GND 16 Vcc = 15v Nom
ECG9383
1 In B 9 Oe
2 In C 10 Od
3 LT 11 Oc
4 B1/RBO 12 Ob
5 RB1 13 Oa
6 In D 14 Og
7 In A 15 Of
Hope this helps!
Chuck
> Hi Chuck (and Bruce),
> information I want.
> nand gate open
> collector".
> open collector".
> Phil.
> From: "Chuck Drew" <chuckdrew@y...>
> > Greetings,
> NTE
> series
> couls
> > Chuck
> > > Hi all,
> of
> > > the functions (like
> need
> > > more than that.
> help
> > > Phil.
> ignored.
Do You Yahoo!?
I'll keep your e-mail address for the next ones... ;-)
Phil.
Sent: Tuesday, August 13, 2002 7:28 PM
> Greetings again,
> ECG9332
> ECG9383
> 1 In B 9 Oe
> 2 In C 10 Od
> 3 LT 11 Oc
> 4 B1/RBO 12 Ob
> 5 RB1 13 Oa
> 6 In D 14 Og
> 7 In A 15 Of
> Hope this helps!
> Chuck
http://www.yesic.com/~bergesys/clk/ecg.htm
and see if that helps.
Leroy
> >Hi all,
> >Phil.
> >Phil -
> Regards,
> Bruce Bates
Phil.
Sent: Wednesday, August 14, 2002 1:51 AM
> Try:
> Leroy
> > >Hi all,
components ?
> > >Phil.
> > >Phil -
> > Regards,
> > Bruce Bates
and
