ADC serial question
I have a ADS7841P-ND (four channel ACD 12 bit converter) I want to use, and I
am having trouble designing the serial interface. The datasheet states that
the chip processes the data on the High-to-low transition of the external
clock pulse. I have to send a string of bits to the chip for each reading in
sync with the clock, and the data is transmitted back after a specific # of
clock cycles to an input pin. My main question is, would using two Output
lines and one input work for this chip? My idea is to have on pin act as the
clock, and the others receive the data in sync. Does the clock have to be a
regular stream of pulses? How do I know when to read the Input pin? Thanks.
Sincerely,
Sean
Sincerely,
Sean
They did all the hard work for you..
If by chance the device you are using is a "I2C device there is also
built in support for that in the BS2P.
Mike B.
Sent: Monday, August 12, 2002 11:15 AM
Subject: [noparse][[/noparse]basicstamps] ADC serial question
and I
that
in
of
the
a
Thanks.
> Sincerely,
> Sean
