Robot navigation around an object
Hi all: I have a small robot with a range finder on the front. What I want
to do if I sense an object is
1)stop
2) rotate 30 degrees left, take a range reading and store it
3) rotate 15 degrees left, take another reading store it
4) rotate back to center or 0 degrees, take a reading store it
5) rotate right 15 Degrees etc
6) rotate right 30 degrees etc.
When I am done with range readings I may have a string, or table that looks
like the following in inches.
100,110,10,30,90 with 100,110 being left, 10 being the center, 30 and 90
being right.
I then want the robot to perform some logic on those 5 numbers and determine
that the left hand direction is the best direction to turn, because there is
a range of 100 inches that direction.
My problem is I am stumped on how to actually program this.
I know I can store values in a string, but how do I search on the string,
find the highest value, and then know what degree setting of a compass that
value is, to turn the robot in that direction. The first 100 value for
instance may indicate the robot would have to turn 30 degrees left and move
forward. An if-then sequence seems horribly messy at best, I can't figure
out if branch or lookdown tables will help me either.
My robot works like a tank, I send power to motors in a timed manner to
determine how many degrees I rotate. There is no position feedback, but my
theory should still work, albeit wheels spinning etc. I had thought I could
just change the time/turn variable of the motor's depending on the range
value that is best for movment forward. If position one in my table(value
100) then turn 30 degrees left etc, BUT how to come up with which of the 5
positions is best?
If anyone can give me some pointers on how to program this I would
appreciate it.
Very respectfully, your obedient servant.
Kerry
Admin@M...
WWW server hosting [url=Http://mntnweb.com]Http://mntnweb.com[/url]
Kerry Barlow
p.o. box 21
kirkwood ny
13795
607-775-1575
1)stop
being right.
positions is best?
appreciate it.
Kerry
Admin@M...
Kerry Barlow
p.o. box 21
kirkwood ny
13795
607-775-1575
Just have the robot scan from left to right and only record the position
where it measures the farthest distance on the ranger. You turn the robot
that direction and go.
> 1)stop
looks
> being right.
determine
is
that
move
could
> positions is best?
> appreciate it.
