Low-Cost Humidity Sensor? — Parallax Forums
edited 2002-11-06 12:59 in General Discussion
Hello,
Parallax is looking for a low-cost humidity sensor. We'll accept the fact
that precision and cost are trade-offs, too. Our target cost is less than a
buck, including any support circuitry. Can anybody provide some direction on
parts we might be able to use for this purpose?
The application is for a simple project designed for the experimenter,
hobbyist or student.
Ken Gracey, Parallax
http://www.parallaxinc.com and http://www.stampsinclass.com
Microcontroller Application Cookbook Vol 1&2 features BASIC
Stamp code examples for almost any interface you can
imagine. $54.95 for both volumes at www.parallaxinc.com/mac
    edited 2002-08-08 18:08
    Hi Ken,
    We used some "hygristors" a while back for this purpose. They are little
    more than glass plates with some sort of black smear of lithium chloride
    or carbon on them. They change resistance with humidity. These were
    gov't surplus from some radiosondes. I'm not sure how long these last.
    These can't cost much to make, but I have no idea how much new ones are:
    http://www.ysi.com/veco/media/temp.gif
    Humicaps are also around, but I don't know if you can get them for a
    buck. http://www.vaisala.com/
    Others:
    Ohmic Instruments (MD) http://www.ohmicinstruments.com/sensors.html
    Rotronic (NY) http://www.rotronic-usa.com/
    Don't know if any of them could go under $1.
    That ought to get you started.
    Al Williams
    AWC
    * Floating point math for the Stamp, PIC, SX, or any microcontroller
    http://www.al-williams.com/awce/pak1.htm
    > From: Ken Gracey [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=k1fe5n4Frltqak9mXmfMGxZ4P6EAW4N45VW2bOEYkG5y5FH5m4myzqUDV8hy91rcjjo6BBRt_fL4UCcCp-6fRg]kgracey@p...[/url
    > Sent: Thursday, August 08, 2002 11:42 AM
    > Subject: [noparse][[/noparse]basicstamps] Low-Cost Humidity Sensor?
    > Hello,
    > accept the fact that precision and cost are trade-offs, too.
    > Our target cost is less than a buck, including any support
    > circuitry. Can anybody provide some direction on parts we
    > experimenter, hobbyist or student.
    > Thanks,
    > Stamp code examples for almost any interface you can imagine.
    > from the same email address that you subscribed. Text in the
    edited 2002-08-08 18:28
    I am assuming all the big names are too expensive:
    http://content.honeywell.com/sensing/prodinfo/humiditymoisture/
    http://www.geinet.com/
    GE Panametrics http://www.panametrics.com/
    http://www.cosa-instrument.com/
    Phillips
    BC Components (these are about $4 in big quantity, if I recall)
    Also, a colleague just suggested: http://www.humirel.com/ but again no
    idea if $1 is reasonable.
    Al Williams
    AWC
    * NEW: PAK-VIa - Read PS/2 keyboards or mice -- double the buffer, lower
    current consumption.
    http://www.al-williams.com/awce/pak6.htm
    > From: Ken Gracey [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KrfMQOBNi2b4lKkY5bNpG9rdTfyekDiDWcKIrbzOQg_5Q5zEugxN1C5OViYuP7iP-BFfCWpRcC1yxA2kSTqAaEas]kgracey@p...[/url
    > Hello,
    > Thanks,
    edited 2002-08-08 19:14
    You are going to be hard pressed for find one for a buck or less
    unless you buy a shipping container full. The really cheap sensors
    are suseptable to dust/dirt, oils, and prolonged exposure to high
    temp/humidity can affect there reliability. Use of a sintered brass
    or teflon filter will help prevent dust/dirt from contaminating the
    sensing element. The HIH series Honeywell sensors are almost immune
    to harsh conditions but the sensors cost $25 each.
    Another issue is the linearity of the sensor. A capacitive or
    resistive sensor could be used with a 555 timer to vary the frequency
    as the RH changes. I suppose if your just looking for a ballpark
    figure that would work.
    But for a buck........
    Maybe 3 bucks if your lucky.
    Jason
    > Phillips
    no
    > Al Williams
    > AWC
    lower
    > > From: Ken Gracey [noparse][[/noparse]mailto:kgracey@p...]
    > > To: basicstamps@y...
    > > Hello,
    > > Thanks,
    > > basicstamps-unsubscribe@y...
    edited 2002-08-08 21:37
    >Thanks, Ken Gracey, Parallax
    hehe! happy hunting...
    How about a good old wet bulb thermometer? All you need is two small
    temperature sensors (thermistor? thermocouple?) and a little bit of
    wet cotton wick over one. RCtime interface. Hey, add a
    stamp-controlled fan to keep the air moving, and how about a
    stamp-contolled gizmo to keep the wick wet!?
    Here is a cheap trick to make a "discrete" humidity sensor: Coat an
    interdigitated grid with a saturated table salt (NaCl) solution, then
    dry it out with a hair dryer. The resistance across the grid is high
    when the %RH is below 75% but drops dramatically when the %RH is
    above 75%. Different salts have different transition humidity, for
    example, lithium cloride (LiCl) at 11% or potassium nitrate (KNO3) at
    95%. AC xitation with a '555 and COUNT in the Stamp. It is possible
    to make formulations of salts and binders that display a continuous
    change of resistance with humidity, and these were popular for use in
    old radiosondes. But they are fragile and the calibration is
    terrible.
    Remember cobaltous cloride from your chemistry set? On a piece of
    blotting paper it is blue at low humidity and pink at high humidity.
    I don't know what you could do with that and one of those new TAOS
    color sensors.
    Here is another manufacturer with relatively low cost humidity
    elements ($5 to $10):
    Also, here is a smart sensor (~$20):
    http://www.sensirion.com/en/sensors/humidity/default.htm
    -- regards
    Tracy Allen
    http://www.emesystems.com
    mailto:tracy@e...
    edited 2002-08-08 22:18
    Ahaha!!.... I suppose if you "create" an interdigitated "finger
    capacitor" by bridging the copper rings on a pref-board of say 3x3 inches,
    you would have enough bimetallic difference between the solder and
    copper that you could have a measurable difference in capacitance
    proportional to humidity without using any salt if you simply include
    the "capacitor" in a simple RC oscillator.
    >then
    >terrible.
    >color sensors.
    > -- regards
    > Tracy Allen
    > mailto:tracy@e...
    Beau Schwabe Mask Designer IV - ATL
    National Semiconductor Enterprise Networking Business Unit
    500 Pinnacle Court, Suite 525 Wired Communications Division
    Mail Stop GA1 Norcross, GA 30071
    How about human hair and a pot ?
    I have an old circular chart recorder, temp and humidity.
    they used either human or horse hair and as the humitity changed the
    mechanical shaft moved allowing the arm to sweep across the 8"
    chart. That is 3 inches of mechanical movement. Now THAT is in the
    experimentors category. and it is relativly cheap, pot's with shafts
    being more than your target price.
    Dave
    the fact
    less than a
    direction on
    experimenter,
    small
    then
    high
    at
    possible
    in
    > terrible.
    humidity.
    > color sensors.
    > -- regards
    > Tracy Allen
    > mailto:tracy@e...
