driving a 24V solenoid with the ULN2003
Ignorant questions...I want to send 24V to a solenoid I'm controlling
with the BS2. Have never used the ULN2003 before.
1) Power Source: The application will run out-of-doors for an
extended period of time. Any suggestions re. power source?
2) ULN2003 I/O configuration: Let's assume I'm sending my input
signal through P4 of the BS2. I'll connect P4 to 1B (Pin1) of the
ULN2003. Do I connect 1C (Pin16) of the ULN2004 to the solenoid.
3) ULN2004 Power configuration: Positive terminal of power source to
COM (Pin 9) of ULN2003; negative terminal of power source to E (Pin
8) of ULN2003.
4) Solenoid Configuration: 1C of ULN2003 to positive terminal; common
ground to negative terminal.
Am I close?
Thanks!
8) of ULN2003.
Am I close?
Thanks!
from looking at the data sheet I might think that a
24v coil would pull more than 500ma. That's not much
for a relay or solinoid, IMO.
I have been looking at the K3010P (Mouser) triac,
which looks like it can pull down 3 amps. I have
bought several of these and was planning on driving
them with a 2n2222A but haven't had time to hook them
up to their own power supplies and test off-line from
the stamp.
Let me know what you think . . .
> out-of-doors for an
> source?
> sending my input
> (Pin1) of the
> the solenoid.
> power source to
> source to E (Pin
> 8) of ULN2003.
> terminal; common
> Am I close?
> Thanks!
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do You Yahoo!?
HotJobs - Search Thousands of New Jobs
http://www.hotjobs.com
6: A Serial Stepper Controller in the BS1 stamp notes on the Parallax
website. Note that the ULN2003 will drive up to 500 mA in each of its 7
Darlington channels. I suspect that you can parallel 2 or more channels
for higher current capacity, but I could be wrong about that. See
answers below.
Dennis
From: donnmoidaho [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AQOhrcPdeXAg2PfHjsxNEjSsW_xnwITfwSaFevv677lsYQYngoQvY1sKf_mPuJ3qmaXZUVAIjuBP]donnmo@l...[/url
Sent: Wednesday, August 07, 2002 7:48 PM
Subject: [noparse][[/noparse]basicstamps] driving a 24V solenoid with the ULN2003
Any with enough current capacity in a weather-proof enclosure.
ULN2003.
That is correct.
Yes, to the solenoid Common, or negative terminal. Also, connect a 1K
ohm resistor (1/2 watt) from Pin 16 to +5v. (See Stamp Note 6.)
Definitely not. You will blow out the 2003.
8) of ULN2003.
Yes. Also, connect Pin 8 to the Stamp ground.
No.
common
No. See below.
A brief summary:
Connect the power source positive terminal to the positive terminal of
the solenoid. Connect the negative terminal of the solenoid to ULN2003
Pin 16. When the Stamp pin signal to ULN2003 (Pin 1) goes high, the
output goes low, driving the solenoid negative terminal to ground. This
activates the solenoid. Again, watch the current limit of 500 mA.
Dennis
