Multiplexer
Does anyone have any suggestions for what is a good multiplexer for
use with a BS2? I have a 4067B but I don't have it working yet,
meaning that I can sink B, C, D, /E, and pin 1 to ground, pulse A and
get no output from out 1. The idea is to control 65 to 65 solid state
relays from one BS2 using the multiplexers in 4 groups.
Chuck
Chuck
chuckdrew@y... writes:
Chuck, you can drive up to eight 595 shift registers with a BS2. That will
give you 64 outputs. I use the same system, and I have the 595s driving
ULN2803
8-channel Darlingtons, which will sink 500ma per channel.
Sid
to the BS2 is with the 74HC595 (serial-in/parallel-out shift register). It
takes just three lines (data, clock and latch) to control it and it can be
daisy-chained. I'm not sure that you can put eight in a chain, but it would
be worth looking into.
-- Jon Williams
-- Parallax
In a message dated 8/7/02 6:54:23 PM Central Daylight Time,
serial-in/parallel-out shift registers with 32 outputs in a single
chip. Sorry I don't have part numbers, but if they can be daisy-chained,
would give you the 64 outputs with only two I.C.'s.
Have a look,
Tim
At 08:00 PM 8/7/2002 -0400, you wrote:
>It may be a bit simplistic ... but my favorite way to add a bunch of outputs
>-- Jon Williams
>-- Parallax
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Timothy Medema
CrystaLite, Incorporated
3307 Cedar St. (425) 745-6000 800-666-6065
Everett, WA 98201 Fax: (425) 257-0232
www.crystaliteinc.com
<mailto:timm@c...>timm@c...
The information transmitted is intended only for the person or entity to
whom it is addressed and may contain confidential and/or privileged
material. Any review, retransmission, dissemination or other use of, or
taking of any action in reliance upon, this information by persons or
entities other than the intended recipient is prohibited. If you received
this in error, please contact the sender and delete the material from any
computer.
On Thursday 08 August 2002 11:04 am, you wrote:
> Also, Allegro MicroSystems www.allegromicro.com has
> Have a look,
> Tim
> > outputs to the BS2 is with the 74HC595 (serial-in/parallel-out shift
> > register). It takes just three lines (data, clock and latch) to control
> > it and it can be daisy-chained. I'm not sure that you can put eight in a
> > chain, but it would be worth looking into.
> >-- Jon Williams
> >-- Parallax
> Timothy Medema
> computer.
Registered Linux user #223705
Give me ambiguity or give me something else.
ones who responded to my question. Now, moving on,
I was able to finally get the 4067b multiplexer
working
and I picked up a 74HC595 and tried the experiment
from the Stampworks book with success also. My
questions is, if a daisy chain multiple IC's together,
how do I address the out puts individually, say, to
turn on output 2 on the second chip? This one has me
kinda stumped!
Chuck
> -- Jon Williams
> -- Parallax
> Daylight Time,
> working yet,
> ground, pulse A and
> removed]
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do You Yahoo!?
HotJobs - Search Thousands of New Jobs
http://www.hotjobs.com
> kinda stumped!
Tie all the clock and latch lines together. Shiftout all your data - one
byte per 595 - to the first 595 in the string then pulse the latch.
Allegro has a 32-bit shift register - A6818SA.
Sid
