BS2SX program size control
I am about 90% complete with the code for a project and have
discovered that I am almost out of code space. It is clear that I
will run out before all the code is complete.
I have a few questions that I have not seen addressed on the list:
If they have, please point me in the right direction, and I
appologize. I would also be interested in any articles or books that
might have some insight.
Is it possible to minimize code size through different
structure/architectures? For example, if I have a small subroutine of
only 2-3 lines, and I only need to call it from 2 different places,
will the code be smaller if I just embed the routine 2X, or if I
leave it a subroutine? The manual implies that a single subroutine
will use less space.
I understand that commented lines (') don't get tokenized and
therefore do not contribute to program size. If I am wrong that
would help some.
Are there any instructions that are known to use more than the normal
amount of program space? (e.g. does the branch statement use more
space than 4 If .. then statements)
These may seem like silly questions, but I will need to find a way to
save every byte.
would help some.
save every byte.
http://www.faq-pro.com/faq/index.php?qframe=1&faq=1&article=53
Al Williams
AWC
* NEW: PAK-VIa - Read PS/2 keyboards or mice -- double the buffer, lower
current consumption.
http://www.al-williams.com/awce/pak6.htm
> From: c_holm10017 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=vEQjJ5awiX_J2XDYG1DVvXE5fdRlUc3Vg7DRX6cwEXHZir5dy9L8hO1Jn1ydxMn7gs9vE29sHKOE]cholm@m...[/url
> Sent: Wednesday, August 07, 2002 2:52 PM
> Subject: [noparse][[/noparse]basicstamps] BS2SX program size control
> would help some.
> save every byte.
> from the same email address that you subscribed. Text in the
Brian Forbes' book "Inside the basic stamp II" is an excellent
resource if you want to understand how the tokenizer does its thing.
<http://members.aol.com/stamp2book/ > The book is technical,and if
you like that sort of thing, you will come away with some very
practical knowledge of how to optimize your programs. But it is not a
"made easy" book.
The best way to gain insight is to try it both ways, with that one
factor being the only difference, and compare the detailed memory
maps. (You know how to view that, right?) Each subroutine call adds
14 bits at the very top of the program, and there is also overhead in
the return, so in the case of very short subroutines, inserting the
statement twice may be better. For example,
' silly subroutine
gohigh0:
high 0
return
will certainly be better handled as
high 0
every time it occurs.
>would help some.
commented lines make no difference in program size, and neither do
labels nor variable definitions or definition of alias variables.
Also, parentheses inserted for clarity (as opposed to essential for
function) make no difference.
One BRANCH will certainly use less than 4 IFs. (try it and see!)
One thing that eats a huge amount of space is text within SEROUT or
DEBUG statements. If you have a lot of text to display, it is better
to put it in DATA statements and have a small routine to read and
display it. For example,
serout 16,$54,[noparse][[/noparse]"simon says stand on your head",cr]
The trouble is, each letter in the string takes up 14 bits in the
interpreter code, whereas, stored as DATA, each letter only takes up
8 bits. There is a lot of overhead in each SEROUT command.
Something like the following can save a huge amount of code space:
head DATA "simon says stand on your head",cr,0 ' null terminated
foot DATA "simon says tap your foot on the floor",cr,0 ' null terminated
pointer=head ' program selects string
gosub showstring
showstring:
i=0
showstringloop:
read pointer+i,char
branch char,[noparse][[/noparse]exitshowstringloop] ' branch saves space over IF here
serout 16,$54,char
i=i+1
goto showstringloop
exitshowstringloop:
return
Despite the subroutine, this pays off rapidly if you have even a few
"simon sez" strings. Since you are using a BS2sx, this kind of
subroutine lends itself to one of the alternate program banks.
Here is another little thing. Let's say you need to set an output to
1 when some variable is greater than 50. I see things like this:
if x>50 then xbig
xsmall:
out5=0
goto onward
xbig:
out5=1
onward:
which is not only ugly (as the Stamp has no capability for
expressions as in THEN out5=1 ELSE out5=0), but uses a lot of eeprom.
You can accomplish the same thing and save a lot of bytes with a math
expression:
out5 = x max 50 - 50 max 1
which comes out the same. I have more of that kind of thing on my
math pages at
http://www.emesys.com/BS2math4.htm#ifThenLet
Even simple things can save a few bits. For example, PAUSE 1024 will
take less space in eeprom than PAUSE 1000, because the Stamp
tokenizer stores powers of 2 more efficiently than other numbers.
>save every byte.
Not at all silly. Saving bytes is the Way of the Stamp.
-- best regards
Thomas Tracy Allen PhD
http://www.emesystems.com
mailto:tracy@e...
I now have hope for a successful complete project.
From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jBNcNZPAiQGie0mJNYFLEcy66O0sf5UtzqwBl8o9RYmw6VtmeiKOCPM0oG0I2eVyV3i9JIVFN9CgNwDZs1o]tracy@e...[/url
Sent: Thursday, August 08, 2002 12:08 AM
Subject: Re: [noparse][[/noparse]basicstamps] BS2SX program size control
"made easy" book.
' silly subroutine
gohigh0:
high 0
return
high 0
>would help some.
gosub showstring
showstring:
i=0
showstringloop:
read pointer+i,char
serout 16,$54,char
i=i+1
goto showstringloop
exitshowstringloop:
return
if x>50 then xbig
xsmall:
out5=0
goto onward
xbig:
out5=1
onward:
expression:
math pages at
>save every byte.
-- best regards
mailto:tracy@e...
This e-mail message may contain legally privileged and/or confidential
information. If you are not the intended recipient(s), or the employee
or agent responsible for delivery of this message to the intended
recipient(s), you are hereby notified that any dissemination,
distribution or copying of this e-mail message is strictly prohibited.
If you have received this message in error, please immediately notify
the sender and delete this e-mail message from your computer.
