Proposed circuit for Basic Stamp to control relays
I have a need to turn on two relays using a basic
stamp for a car audio application. One relay will
turn on the amp, the other will turn on the DC-DC
power supply for the computer. Am I wiring things
correctly by using the transistor on the ground side
of the relays? Do I need to stick a few diodes in any
where.
The dashed lines are proposed lines that I had
questions on. I believe the "C" and "D" lines need to
be connected, but don't think that "A" or "B" should
be connected.
Eventually the Stamp(BS2p) will turn on a few
different 12V fans depending on the temperature.
Any thoughts appreciated. I'm not an electronics guy
by trade (Metallurgical Engineer--so I understand npn
junctions at the electron level...or so I should).
Darrick
__________________________________________________
Do You Yahoo!?
Yahoo! Health - Feel better, live better
http://health.yahoo.com
where.
be connected.
Darrick
Do You Yahoo!?
The schematic you're talking about is not visible...
The transistor(s) you need depend on the current, and of course you need a
diode to protect it.
Do you know the current needed by the relays ?
Phil.
To: <basicstamps@yahoogroups.com>; "Dashpc" <dashpc@yahoogroups.com>
Sent: Wednesday, August 07, 2002 7:46 AM
Subject: [noparse][[/noparse]basicstamps] Proposed circuit for Basic Stamp to control relays
> where.
> be connected.
> Thanks,
> Darrick
> Do You Yahoo!?
You can find a good discussion on controlling relays in the Basic Stamp
FAQ (http://www.wd5gnr.com/stampfaq.htm).
You should not need the resistors going from the transistor base to
ground. You want to drive the transistors into saturation so that the
Vce will be <.3V or so and you'll get a clean fast turn on.
You don't want to connect ground to 12V so A and B should be omitted.
You do want 12V to your relay coils so the other connections look OK
with a few cautions:
1) When an inductor (like a relay coil) has a change in current it
generates a voltage. The amount of voltage is purely dependent on the
time of the change, so you can generate very large voltages. For this
reason you need a flyback diode across the coil. The diode "points"
towards the +12V supply so normally no current flows through it (to
speak of). When a large voltage appears, the diode will shunt it to the
12V buss. Without it, the transistor will blow when you exceed the
breakdown voltage of the BC junction.
2) I'm assuming this is going in a car. A 7805 by itself is a poor
choice for a car. The amount of garbage that is on the 12V (really
13.8V) line when you start the car and at certain other times is
amazing. You might want to preregulate the incoming voltage with a
zener. Nuts and Volts did an article on this some years back, but I
don't remember what technique they used. A power supply that works
nicely on the bench might not survive in a car very long :-)
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
> From: Hartman Darrick [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AAjabu1IJrKFKhriwlLYqhB5fUDBKYZMmnJarwiiTJ57NyU1S8R1FIqzfqai4Nq6awEVh9x80w]ricko73@y...[/url
> Sent: Wednesday, August 07, 2002 12:46 AM
> To: basicstamps@yahoogroups.com; Dashpc
> control relays
> where.
> be connected.
> by trade (Metallurgical Engineer--so I understand npn junctions at the
> Thanks,
> Darrick
> Do You Yahoo!?
> Yahoo! Health - Feel better, live better http://health.yahoo.com
http://www.acroname.com/robotics/info/articles/drivers/drivers.html
Leroy
> where.
> be connected.
> Thanks,
> Darrick
> Do You Yahoo!?
Your link "http://www.wd5gnr.com/stampfaq.htm" is broken.
Leroy
Al Williams wrote:
> Hi Darrick,
> Al Williams
> AWC
> > From: Hartman Darrick [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ubqqx6RcDZVdcznz940zdjjKFMyeqI-hc9UTt-oBYDofUfHeqe9yM2gFv5lLSseYag8vydEF61vW]ricko73@y...[/url
> > control relays
> > where.
> > be connected.
> > Thanks,
> > Darrick
> > Do You Yahoo!?
Al Williams
AWC
> From: Leroy Hall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-XbvGE8pZP_ZirK2BuKY5vAPFsneiE5Xf6vpLUDzU7YvGvt-BdNpD-lqNEuP5iUTDt0WHSsg-6l6]leroy@f...[/url
> Sent: Wednesday, August 07, 2002 9:08 AM
> To: basicstamps@yahoogroups.com; alw@a...
> Subject: Re: [noparse][[/noparse]basicstamps] Proposed circuit for Basic Stamp
> to control relays
> Dear Al,
> Leroy
> Al Williams wrote:
> > Hi Darrick,
> > Stamp FAQ (http://www.wd5gnr.com/stampfaq.htm).
> so that the
> be omitted.
> connections look OK
> dependent on the
> voltages. For this
> > the 12V buss. Without it, the transistor will blow when you
> exceed the
> > Al Williams
> > AWC
> > * Floating point A/D http://www.al-williams.com/awce/pak9.htm
> > > From: Hartman Darrick [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hvdGH3eP1wGow2Fv0XvZ09Voecp-6Es2NYbOk3GUBpQWRLMVjQcCaxp6a68RiyWG6rAIvaX7WYQ]ricko73@y...[/url
> to control
> > > relays
> > > power supply for the computer. Am I wiring things correctly by
> > > using the transistor on the ground side of the relays?
> Do I need to
> > > stick a few diodes in any where.
> > > be connected.
> junctions at
> > > the
> > > Thanks,
> > > Darrick
> > > Do You Yahoo!?
> the Subject
--- In basicstamps@y..., "Al Williams" <alw@a...> wrote:
> Works from here... Anyone else having problems with it?
> Al Williams
> AWC
> > From: Leroy Hall [noparse][[/noparse]mailto:leroy@f...]
> > To: basicstamps@y...; alw@a...
> > to control relays
> > Dear Al,
> > Leroy
> > Al Williams wrote:
> > > Hi Darrick,
> > so that the
> > be omitted.
> > connections look OK
> > dependent on the
> > voltages. For this
> > exceed the
> > > Al Williams
> > > AWC
> > > > From: Hartman Darrick [noparse][[/noparse]mailto:ricko73@y...]
> > > > To: basicstamps@y...; Dashpc
> > to control
> > > > relays
> > Do I need to
> > > > be connected.
> > junctions at
> > > > the
> > > > Thanks,
> > > > Darrick
> > > > Do You Yahoo!?
> > > > basicstamps-unsubscribe@y...
> > the Subject
