I need Help
Hello to all
My name is Nick and I am new to programming. I have a Parallax 8051 BS2
microcontroller with a BPK-216 Series LCD. I am looking for sample code to
enable my BS2 to generate text such as "hello" and get the text to either
scroll, flash on and off and clear itself for new text to be generated. My goal
is to put together a program that will allow text to a song to be generated and
displayed on the LCD with sounds of a song for example "Mary had a little lamb"
being played using the FREQOUT commands. Is this a feasable project idea or do I
need to simplify it? If it is doable then all I need is some sample commands and
programs to give me a good start on my project ASAP.
Do You Yahoo!?
Yahoo! Health - Feel better, live better
Do You Yahoo!?
it reqires some reading time. Regards, John.
http://www.parallaxinc.com/downloads/Documentation/StampWorks/StampWorks%20Versi\
on%201.1a.pdf
http://www.hth.com/filelibrary/bs2-ic/
--- nixon bruce <nixman101@y...> wrote:
> Hello to all
> have a Parallax 8051 BS2 microcontroller with a
> get the text to either scroll, flash on and off and
> a song to be generated and displayed on the LCD with
> lamb" being played using the FREQOUT commands. Is
> this a feasable project idea or do I need to
> sample commands and programs to give me a good start
> on my project ASAP.
> Do You Yahoo!?
> removed]
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do You Yahoo!?
http://health.yahoo.com
John Remington wrote:Here are two sites I've found with loads of info, but
on%201.1a.pdf
--- nixon bruce wrote:
> Hello to all
> on my project ASAP.
> Do You Yahoo!?
> removed]
> ignored.
Do You Yahoo!?
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
Do You Yahoo!?
distance then move then turn again that works with stamp 2e
