Pocket Watch Help
Hi All,
Just got a Pocket Watch module, and I can't seem to make sense of the code
supplied with it, or figure it out at all. Guess I'm thick, that'll be no
news to my Mom...
Anyway, anybody have a working example of Pocket Watch code? Just something
that say sets the time and reads out using the debug command. Alarm set and
use would be nice too.
Regards and thanks,
Jonathan Peakall
www.madlabs.info
news to my Mom...
Regards and thanks,
Jonathan Peakall
www.madlabs.info
Here is a code I used to check the Pocket Watch with a BS2-SX
Don't get confused with lines related to the display, they may be useless...
it's only for test purpose :-)
Hope this helps...
Phil.
'{$STAMP BS2SX}
N9600 con $40F0
N2400 con $43FD
I con 254
CLR con 1
LINE2 con 192
L1_C7 con 135
' clock variables
ss var byte
mm var byte
hh var byte
dd var byte
mo var byte
yl var byte
yh var byte
output 0 ' to LCD serial input
output 1 ' to LED
output 6 ' to clock FM input
input 7 ' from clock TM output
high 6
pause 1000
SetTimeExtended:
ss=0
mm=10
hh=7
dd=22
mm=7
yl=00
yh=20
SEROUT 6,N9600,[noparse][[/noparse]$55,$10,ss,mm,hh,dd,mm,yl,yh]
DEBUG "Initialized.",cr
LoopClock:
PAUSE 2000
ReadTimeExtended:
SEROUT 6,N9600,[noparse][[/noparse]$55,$12]
SERIN 7,N9600,[noparse][[/noparse]ss,mm,hh,dd,mo,yl,yh]
DEBUG "Time : ",dec2 hh,":",dec2 mm,":",dec2 ss," ",dec2 mo,"/",dec2
dd,"/",dec2 yh,dec2 yl,cr
GOTO LoopClock
BadReadEx:
DEBUG "Read Extended bad",cr
GOTO LoopClock
loop1:
pause 500
high 1
serout 0,N9600,[noparse][[/noparse]I,CLR]
pause 300
low 1
serout 0,N9600,[noparse][[/noparse]126,"CA MARCHE !"]
goto loop1
Sent: Tuesday, August 06, 2002 2:22 AM
Subject: [noparse][[/noparse]basicstamps] Pocket Watch Help
> Hi All,
> news to my Mom...
something
and
> Regards and thanks,
> Jonathan Peakall
> www.madlabs.info
Thanks for the help! It still isn't working quite right..
When I use your code, it stalls at the serin command I marked with *** in
the ReadTimeExtended function. If I remove it, the code loops on, but of
course doesn't update the time.
Could I have a bad module?
Thanks again,
Jonathan Peakall
> '{$STAMP BS2SX}
> N9600 con $40F0
> N2400 con $43FD
> I con 254
> CLR con 1
> LINE2 con 192
> L1_C7 con 135
> ' clock variables
> ss var byte
> mm var byte
> hh var byte
> dd var byte
> mo var byte
> yl var byte
> yh var byte
> output 1 ' to LED
> high 6
> pause 1000
> SetTimeExtended:
> ss=0
> mm=10
> hh=7
> dd=22
> mm=7
> yl=00
> yh=20
> LoopClock:
> PAUSE 2000
> ReadTimeExtended:
> ***SERIN 7,N9600,[noparse][[/noparse]ss,mm,hh,dd,mo,yl,yh]
> GOTO LoopClock
> BadReadEx:
> GOTO LoopClock
> loop1:
> pause 500
> high 1
> pause 300
> low 1
> goto loop1
> From: "Jonathan Peakall" <jpeakall@m...>
> > Hi All,
code
no
> > news to my Mom...
> something
> and
> > Regards and thanks,
> > Jonathan Peakall
> > www.madlabs.info
and
If you are using the DS1302 you can not serin/serout data. You have to use
shiftout/shiftin.
Sid
I'm not sure if I am using a DS1302. I know the hardware as: a Pocket Watch
B and a B2SX board of education. I bet you are right, as it is the serin
command that is giving me trouble. I'll go read up on the shiftin/shiftout
commands, but do you or anyone else have a working example?
Thnaks for your time,
Jonathan Peakall
> For Jonathon
use
> shiftout/shiftin.
> Sid
jpeakall@m... writes:
I have the code for the DS1302 if it can be of any help. I suggest you e-mail
jonwms@a... and ask him if you need to use shiftout/shiftin. If so, I can
send you the code.
Sid
The Pocket Watch B is made by a company called Solutions
Cubed. If you go to their web site at www.solutions-cubed.com they have
Basic Stamp code examples (yes, you do use the SERIN and SEROUT commands)
and application notes for direct download under the "Downloads" category.
Take a look,
Tim
At 05:22 PM 8/5/2002 -0700, you wrote:
>Hi All,
>news to my Mom...
>Regards and thanks,
>Jonathan Peakall
>www.madlabs.info
Send the code along, I'll give it a whirl. I e-mailed Jon to ask as well.
Thanks!
Jonathan Peakall
e-mail
can
> send you the code.
> Sid
I have done that. The SERIN command stalls the program, and if I include a
"badloop" label, it goes there. So I assume I'm not managing to communicate
with the POcket Watch. The code example I downloaded from the website does
the same thing as the code snippet that Phil kindly sent. I am going to call
Solutions Cubed when they open. Perhaps I have a bad module?.
Jonathan Peakall
> Hello Jonathan,
> Take a look,
> Tim
Jonathan, I was in error about the sshiftin/shiftout. Go to the Solutions
Cubed site and you can dwonload the code.
Sid
> Thanks,
> Jonathan Peakall
Jonathan, let me know what happens. I'm curious and would like to add your
findings to my bundle of "Notes".
Sid
a link to the datasheet:
http://www.solutions-cubed.com/Download%20Data/PocketWatchB/pwb_2v4.PDF
Watch
