SV: [basicstamps] Problem with DATA command
Greetings!
Sorry, but the Editor doesn't know about constants defined in any other file
than the one you're working in.
I suggest that you add this in the beginning of the file:
tekst1 CON 0
tekst2 CON 40
tekst3 CON 80
and so on...
Trygve
http://home.c2i.net/trygveh/english/
Opprinnelig melding
Fra: De Meester, Michel [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=K7C16QnImGsvdwXFQtGO3ymynb1l2MxanG2H3JkSHAntM6JXrPhtVL_hATo9CENJZZi5amaNVC5M6rfavnviLjOmA38QIZSQPA]Michel.De.Meester@u...[/url
Sendt: 5. august 2002 11:29
Til: 'basicstamps@yahoogroups.com'
Emne: [noparse][[/noparse]basicstamps] Problem with DATA command
Hello stampers,
while using the DATA command I ran into next problem:
(I'm using a BS2P40)
I put a bunch of text data into slot 1 using (sorry the labels and remarques
are in Dutch)
tekst1 data " Tekstblok 1 "
data "01234567890123456789"
tekst2 data " Tekstblok 2 "
8<
>8
tekst25 data " Tekstblok 25 "
This makes 2000 bytes of data, I want to use 40 byte blocks as templates to
fill a 4*20 LCD, I know I waste a lot of space this way but I don't need it
for code so.....
In the main routine in slot 0 I put:
store 1
tekstplaats=tekst2 'get the data starting at "tekst2", here occures the
error
gosub tekstweergeven
pause 5000
stop
tekstweergeven:
for tekstteller=tekstplaats to tekstplaats+40 'read 40 bytes of
data
read tekstteller,tekst
debug tekst
next
return
I get an "undefined symbol" error during tokenizing at the
"tekstplaats=tekst2" line, it seems that the constant "tekst2" that is
assigned at the data line in slot1 isn't recognised as a constant in slot0
All the other variables are properly declared, I don't get any other errors
Anybody an idee????
Michel,
Met vriendelijke groetjes,
> Michel De Meester
> Biotechnisch Onderhoud
> Universitair Ziekenhuis Antwerpen
> Wilrijkstraat 10
> 2650 Edegem - B
> tel: ++32 (0)3 821 36 47
> e-mail: michel.de.meester@u...
tekst1 CON 0
tekst2 CON 40
tekst3 CON 80
and so on...
Trygve
Opprinnelig melding
Hello stampers,
are in Dutch)
8<
>8
for code so.....
store 1
error
pause 5000
stop
tekstweergeven:
data
debug tekst
next
return
Anybody an idee????
Michel,
> Michel De Meester
> Wilrijkstraat 10
> 2650 Edegem - B
store 1
i=2 ' plaat #1->25
tekstplaats=(i-1)*40
>Greetings!
>tekst1 CON 0
>tekst2 CON 40
>tekst3 CON 80
>and so on...
>Trygve
Opprinnelig melding
>>Fra: De Meester, Michel [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=auciohYxB9YzIG2qxdlZPiYd9l0fj4srN8CRDAk9Cyz0YL7gqoT9gvPtxwljSaghy-RUOuhKK94M-K2dRBDzjLJuHsvQClk]Michel.De.Meester@u...[/url
>>Hello stampers,
>>are in Dutch)
>>8<
>8
>>for code so.....
>>store 1
>>error
>>pause 5000
>>stop
>>tekstweergeven:
>>data
>> debug tekst
>> next
>>return
