programing help
Need help with serout command on stamp2.
sending step code to little stepu controller for # of steps
This code work's fine serout 10,baud,[noparse][[/noparse]"{E -200}"]
This code does not
dist var word
dist = -200
serout 10,baud,[noparse][[/noparse]"{E sdec dist}"]
I am not sure how to set this up any help would be appreciated.
Thanks max
This code does not
dist var word
dist = -200
Thanks max
this is more like a shot in the dark but try this serout 10,baud [noparse][[/noparse]"{e",dec
dist, "}"]
i've no way of trying this but i took the format from the last page of the
step-u spec sheet.
regards ian
To: basicstamps@yahoogroups.com <basicstamps@yahoogroups.com>
Date: Sunday, August 04, 2002 12:14 AM
Subject: [noparse][[/noparse]basicstamps] programing help
>This code does not
>dist var word
>dist = -200
>Thanks max
>from the same email address that you subscribed. Text in the Subject and
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Sent: Saturday, August 03, 2002 8:15 AM
> This code does not
> dist var word
> dist = -200
> Thanks max
I must not have that data sheet.
thanks Max
you can get the pdf from www.tla.co.nz
regards
ian
Date: Sunday, August 04, 2002 10:52 AM
>Thanks a bunch Ian that code worked fine.
>thanks Max
Ian Lawson <irlawson@i...> wrote: hi max,
regards
ian
>thanks Max
from the same email address that you subscribed. Text in the Subject and Body of
Do You Yahoo!?
Yahoo! Health - Feel better, live better
