Dallas i-button
I am using the DS1986 EPROM i-button which I am trying to read data
from. To read memory I send it a $F0 which the instructions call for
then it requires a 2 byte memory address to start reading from. I
have been using the commands below.
OWOUT 15,1,[noparse][[/noparse]$CC,$F0,$00,$00]
FOR I = 0 TO 100
OWIN 15,0[noparse][[/noparse]VARIABLE]
DEBUG VARIABLE
NEXT
Most of the data that I get out is ok, but there is some garbled
text. That is one of the problems. The other problem is the 2 byte
address after the $F0 doesnt seem to affect where it starts reading
from. I change it from $00 $00 to anything else and it still starts
reading from the beginneing. Has anybody used this i-button and know
what is going on here, or what I am doing wrong?
Are there certain characters that DEBUG can't handle? Everything that
I put into the i-button was text that I generated using MS notepad.
Dave
FOR I = 0 TO 100
DEBUG VARIABLE
NEXT
Dave
Anything that is less than 32 (space) could give you trouble. Some codes
below 32 are used as control characters and use the bytes that follow as data.
You might want to check the character value for being at least 32 before
sending it to the DEBUG window.
-- Jon Williams
-- Parallax
In a message dated 8/2/02 11:13:42 AM Central Daylight Time,
dwright3@a... writes:
for
> FOR I = 0 TO 100
> DEBUG VARIABLE
> NEXT
know
that
> Thanks
> Dave
I fingered it out. This i-button is composed of 256 pages of 256
bits. Every page uses 4 bytes for CRC data of which I was trying to
print using DEBUG. This is where I was getting my garble. So the
world is as it should be and everything makes sense...........I think.
Dave
