Hooking up an LED
I'm new to BASIC Stamps, and I have just recently received my BASIC Stamp
Rev. D. starter kit, and I want to know how I hook up an LED to the
prototyping area? I have an LED and a 470 ohm resistor (1/2 watt); however,
I don't see how I hook the resistor up to an I/O pin and then to the LED?
If someone could enlighten me on this process that would be great. Please
be as specific as possible as I am a newbie and admit my inferiority.
-Paul
_________________________________________________________________
Send and receive Hotmail on your mobile device: http://mobile.msn.com
-Paul
And Customizing The BASIC Stamp Computer. Not only will it help you with
programming, it has some good information on fundamental electronics AND it
shows how to build connectors for those pesky pins. I'm assuming you don't
want to do any soldering....
-- Jon Williams
-- Parallax
In a message dated 8/1/02 9:25:08 AM Central Daylight Time,
basic_stamp@h... writes:
> however,
them:
http://www.elexp.com/bb_0mf1.htm
The female to female will plug into those pins. A F/M will plug between
a pin and a breadboard. Scott also sells these at www.seetron.com (see
Connectamundos) but no F/M ones.
Not our main thing anymore, but we still make the ASP-II
(http://www.al-williams.com/awce/asp2.htm) that lets you build Stamp
circuits on a breadboard which is a lot easier (although this if for the
Stamp II).
Al Williams
AWC
* NEW: PAK-VIa - Read PS/2 keyboards or mice -- double the buffer, lower
current consumption.
http://www.al-williams.com/awce/pak6.htm
> From: jonwms@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mcoB6IaXwMEpqouZSpHEqJSy7W-ECz-Q-C5KCR3Tj6tpzpi3yoS5sxRbQZPLPeifU8xz-Q]jonwms@a...[/url
> Sent: Thursday, August 01, 2002 10:02 AM
> Subject: Re: [noparse][[/noparse]basicstamps] Hooking up an LED
> I would sincerely suggest you get a copy of Scott Edwards'
> book: Programming
> help you with
> electronics AND it
> assuming you don't
how you would connect everything together.
Basic Stamp I/O pin <- female-female -> 470 ohm resister <- female-female ->
LED
Where exactly do you connect everything to the prototyping area, and how?
Al, you mentioned that a "...F/M will plug between a pin and a breadboard."
That would work on my Basic Stamp Rev D, which just has a small prototyping
area? Al, that site (http://www.elexp.com/bb_0mf1.htm) is great and has
exactly what I need but you must spend a minimum of $20. Do you know of a
better place to purchase jumper wires pre-assembled?
-Paul
>From: "Al Williams" <alw@a...>
>Reply-To: basicstamps@yahoogroups.com
>To: <basicstamps@yahoogroups.com>
>Subject: RE: [noparse][[/noparse]basicstamps] Hooking up an LED
>Date: Thu, 1 Aug 2002 10:12:06 -0500
>You can make the connectors pretty easily. However, I prefer to buy
>them:
>Stamp II).
>Al Williams
>AWC
> > From: jonwms@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=I9KSyTalK7zmdPg48ejy_XasqWUvCGG8Hbus14JoyD-NB4rA2AJMzdPTLxAGfzy70Zpz9w]jonwms@a...[/url
> > book: Programming
> > help you with
> > electronics AND it
> > assuming you don't
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
MSN Photos is the easiest way to share and print your photos:
http://photos.msn.com/support/worldwide.aspx
Most people make their own with heat shrink and "pins" that you can buy
for making connectors.
To answer your real question, there are at least 4 ways to hook up your
LED. Old guys like me tend to wire the LED so it will turn on when the
Stamp pin is low (there is a historical reason for this, but for the
Stamp it really doesn't matter much). On the schematic for the LED the
arrow points one way |< (left in this example). To make the LED light
up, you need to provide a + voltage on the right side of the arrow going
to a lower voltage (usually ground) on the left side of the arrow.
However, if you just hooked, say, a 9V battery to the diode, it would
quickly burn up because the LED would cause too much current to flow.
So the answer is to use your resistor to limit the current. The resistor
can go on either side of the diode, it doesn't really matter. So:
Stamp pin ---- RRRRRR
|< ---- +5V
Or
Stamp pin
RRRRRRR --- +5V
If you prefer to make the LED light on a high:
Stamp pin ---->|
RRRRRR ---- Ground
Or
Stamp pin ----RRRRRR--->|
Ground
You might enjoy the articles in the Stamp FAQ about lighting LEDs:
http://www.wd5gnr.com/stampfaq.htm (yay! Back to the database format; I
hope everyone likes it). Also read http://www.wd5gnr.com/basiccir.htm if
you want to know WHY the resistor is sized as it is.
By the way, we sell 5V LEDs (and you can get them at Radio Shack) that
directly use 5V instead of needing a resistor. Very handy! They really
have the resistor built in.
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: Paul M [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XCm6FCOMTFomXBchkdzKXUjh6-NvjI0Qou42Iv-snVN3NZ5-Uqkhf0XwYqFebn7qD-QWOyihWmwkisP18dYBlO0]basic_stamp@h...[/url
> Sent: Thursday, August 01, 2002 1:19 PM
> Excuse my ignorance but let me get this straight. I'm still
> not clear on
> female-female ->
> LED
> area, and how?
> a breadboard."
> small prototyping
> great and has
> you know of a
> Thanks,
> -Paul
> >them:
> plug between
> >the Stamp II).
> >Al Williams
> >AWC
> >lower current consumption. http://www.al-williams.com/awce/pak6.htm
> > > From: jonwms@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=fxQ2LortiqQUa6LkbO2zmuZIHCQDeBq9VGvMZSOScR97rx89o7Nj9Hsojl7obpNKQcgZw1k]jonwms@a...[/url
> > > book: Programming
> it help you
> > > with programming, it has some good information on fundamental
> > > electronics AND it shows how to build connectors for those pesky
> the Subject
> >and
