locating a push solenoid
I'm looking for a low-voltage push-shaft solenoid that I can drive
from a BS2. Duty cycle of 5-10%, shaft travel of .25 inch, shaft
force of 4 oz., ambient operating temp. of 10-80 degrees F..
Can someone point me to a reputable manufacturer?
Thanks!
--Donn Morse
Thanks!
--Donn Morse
stuff like that
-Jeremy
>Thanks!
>--Donn Morse
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
add extension to rod to either go all the way through the solenoid or around
the coil
maybe using a permanent magnet core ? and bias it with the coil ?
I believe they always "suck in" - you have to do other things to make them
push
richard
Sent: Tuesday, July 30, 2002 4:05 PM
Subject: Re: [noparse][[/noparse]basicstamps] locating a push solenoid
> Check out Allelectronics.com or their catalog - they usually have some
> stuff like that
> -Jeremy
> >Thanks!
> >--Donn Morse
will need a transistor to drive these or a uln or unl2003, you
can order different voltages, force, travel distance and duty
cycles.
http://solenoidcity.com/solenoid/solenoidcatalog.htm
Sent: July 30, 2002 12:59 PM
Subject: [noparse][[/noparse]basicstamps] locating a push solenoid
drive
Thanks!
--Donn Morse
Subject and Body of the message will be ignored.
Sent: Tuesday, July 30, 2002 5:05 PM
> stuff like that
> -Jeremy
> >Thanks!
> >--Donn Morse
you want continuos duty or not ?
Sent: Tuesday, July 30, 2002 5:15 PM
> reverse it mechanically - add a lever
around
> the coil
> push
> richard
> From: "Jeremy Cook" <jscook@c...>
> > stuff like that
> > -Jeremy
> > >Thanks!
> > >--Donn Morse
and
and
A doorbell?
>A doorbell?
Not exactly "push"... more like "overshoot"
Beau Schwabe Mask Designer IV - ATL
National Semiconductor Enterprise Networking Business Unit
500 Pinnacle Court, Suite 525 Wired Communications Division
Mail Stop GA1 Norcross, GA 30071
> >A doorbell?
Heck! Why not a speaker? 1/4 inch travel 4 Oz shouldn't be to difficult.
couple thousand watts, one time use only.
Sent: August 01, 2002 3:58 PM
can drive
inch, shaft
F..
> >A doorbell?
difficult.
Unit
solenoids on the shelf there. It looked like they had about 1/4" of travel
to them. But you'll need a driver transistor for them or something like a
ULN2003 driver. All the solenoids that I have seen can't be driven by any
MCU directly. Either a transistor or a small reed switch is used.
From: Beau Schwabe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lSYGUemVuRPq4eq131rWkgb4Fh7rcITT1ewdA8i9yGlzM7BTZ5-940IrwaTZbyr1DvncTQrnikZ94eLm1m8oSg]bschwabe@a...[/url
Sent: Thursday, August 01, 2002 5:47 PM
>A doorbell?
> >A doorbell?
I have made PUSH solenoids by using a cylindrical
magnet as a plunger, not quite centered in the
solenoid coil. My application was a chime striking
mechanism.
Reg Neale
> > >A doorbell?
> mechanism.
> Reg Neale
Usually, when I think doorbell, I think of the classic DING which is the bottom
strike plate and the DONG which is the top strike plate. The solenoid is
energized
causing the striker to overshoot and hit the DING, where upon release of the
doorbell button, the striker is spring loaded back and strikes the DONG. [noparse]:o[/noparse])
Your method of using a magnet is essentially the same physics of a speaker I
mentioned earlier. With the addition of a magnet in the core of the
"solenoid".
you now have the capability of push and pull depending on the polarity you
apply.
> > mechanism.
> > Reg Neale
>the bottom
>energized
>"solenoid".
>apply.
Of course I had a spring return also, and the ballistic
motion of the magnet (with a plastic "striker" attached
caused it to overshoot and strike the chime just once
per actuation.
AFAIK the classic doorbell chime uses 24VAC, and the
"push" motion is really "pulling" the core into the
solenoid, with the extension sticking out the front end
and striking the chime.
Reg
