infrared motion detector
I want to make a infared motion detector to hook up to my basic
stamp so that i can make it trip a camra to take pic's when something
walks by. is there any way to do this without having a beam that
needs to be triped. Please help have no idea were to start. i dont
have any experence with IR
Thank you,
Malcolm
Thank you,
Malcolm
> From: mal49 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=W1xl3ytmewtSFWdr13N8F8lmTiSxNFJ8pHnNw82T1fXbP4QjBm94FdJx6uRJybtt1_w2zCUeGw]mal49@y...[/url
> Sent: Sunday, July 28, 2002 10:18 PM
> Subject: [noparse][[/noparse]basicstamps] infrared motion detector
> Hi,
> hook up to my basic
> having a beam that
> to start. i dont
I have a packaged IR detector meant to be used with an alarm
system. I bought it some years ago and never used it. It
is much like the kind you see attached to outdoor lights.
It needs a DC supply and has terminals to be connected to
"Normally Closed loop of control panel". I am sure it has a
NC set of contacts in it, which it opens when it is tripped.
It is an IR-830 by IR-TEC. I think I might have bought it
from All Electronics, if I am not mistaken. It looks like a
good way to handle your need.
Dan Thames
> Thank you,
> Malcolm
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will
> be ignored.
sensors for museum exhibits. The most recent motion sensing devices
that I used was a touchless IR switch (range up to 3ft) and a
microwave based motion sensor that can descriminate between incoming
forward motion and outgoing walking away from motion. Radio Shack has
some standard security system IR motion sensors.
Guy
--- In basicstamps@y..., "Dan Thames" <dthames@v...> wrote:
> Malcom,
> > From: mal49 [noparse][[/noparse]mailto:mal49@y...]
> > To: basicstamps@y...
> > Hi,
> > hook up to my basic
> > having a beam that
> > to start. i dont
> Dan Thames
> > Thank you,
> > Malcolm
> > basicstamps-unsubscribe@y...
> > be ignored.
> Thank you,
> Malcolm
We have a new 8-pin PIC that can be used for infrared detector circuits, IR
serial communications, and works great with the Stamp. All you need is
an IR detector, IR LED, a 4MHz resonator, and this 8-pin PIC.
http://www.rentron.com/remote_control/TX-IR.htm
You can find schematics on the same page for a simple IR object detection
circuit with relay control.
-Bruce
webmaster@r...
> Hi,
This is a great site for this application... although the basic stamp is
not technically needed there are some interesting ideas on interfacing
to passive IR detectors.
Michael Burr - Renaissance Man Wanna-Be
The battle for your computer has begun... boycott companies that use
pop up/under ads. Advertisers have no right starting processes on your
machine without your consent!!
> mal49 wrote:
>> Hi,
Yow! I just read my own post and realized that the most important part
is missing.... the URL to the site (DUH...) so sorry!!! Here it is...
any way, great site with ideas on interfacing passive IR detectors to
cheap autowind cameras for automatic photography.
http://www.jesseshuntingpage.com/homebrew-cams.html
