BS2 and Sony Playstation Joypad communication
Hello everybody,
I need to stablish a communication between a BS2 and a PS1
Joypad. In the PS1 Joypad Tech Docs it says that all transmission
are 8 bit serial LSB First. And all timing in the PSX (BS2)
controller bus is syncronous to the falling edge of the clock. The
clock is generated by the PSX ( in this case the BS2 ). The BS2
sends two bytes to the Joykey and then the joykey sends two bytes
with the info of the buttons. I think it's a perfect situation to
use Shiftout and ShiftIn. But I have some little problems with what
mode is the appropiate to use with Shiftin and Shiftout.
I would appreciate your help very much, because I don't
have experience using Shiftin and Shiftout. Thank you in advance.
Aceto, Ezequiel Leonardo
Bernal, Argentina.
Here are the time diagrams:
When the PSX (PIC) wants to read information from a controller it
pulls that devices ATT line low and issues a start command (0x01).
The Controller Will then reply with its ID (0x41=Digital). At the
same time as the controller is sending this ID byte the PSX
(PICmicro) is transmitting 0x42 to request the data. Following this
the COMMAND line goes idle and the controller transmits 0x5A to
say "here comes the data".
As I cannot receive the ID (0x41) and send 0x42 to request the data.
I only send 0x42 and skip the ID from the Joykey.
This would look like this for a digital controller
ATT -____________________________________________________________
| Byte 1 | | Byte 2 | | Byte 3 |
CLOCK ---_-_-_-_-_-_-_-_
_-_-_-_-_-_-_-_
_-_-_-_-_-_-_-_----
0xFF 0x41 0x5A
DATA
__________--__----__--__----__--__---
0x01 0x42
CMND
_____________
__--________--__
Bernal, Argentina.
_-_-_-_-_-_-_-_
_-_-_-_-_-_-_-_----
0xFF 0x41 0x5A
DATA
0x01 0x42
CMND
_____________
__--________--__
> Hello everybody,
> BS2 and a PS1
Aceto,
How is your progress coming on this? Have you
figured it out yet?
Knight Designs
324 West Main Street
Montour Falls, NY 14865
(607) 535-6777
http://www.knightdesigns.com
Do you Yahoo!?
Yahoo! News - Today's headlines
http://news.yahoo.com
posted it to the list. it is not a ps1 joypad, but it
will definetly substitute for it. i imagine that the
method used is identical. here is my post from long
ago:
original message:
Greetings stampers!Does anyone
have any experience interfacing a nintendo or similar
style game controller with a stamp (thinking robotics
applications here). The newer ones only have 3 wires
but a ton of buttons so it has to be serial, does
anyone know where to find information on the protocol?
my message:
It just so happens that i am using a SNES controller
in a robotics project myself. a good place to
research all types of controllers, pinouts, voltage
levels etc., is Gamestationx.com. anyway i just
pulled the codes out of the SNES controller the other
day and they go like this[noparse]:([/noparse]correct to the best of my
knowledge, checked over 2 times)
binary hex
nopress:1111111111111111 ffff
up: 1111011111111111 f7ff
down: 1111101111111111 fbff
left: 1111110111111111 fdff
right: 1111111011111111 feff
select: 1101111111111111 dfff
start: 1110111111111111 efff
y: 1011111111111111 bfff
x: 1111111110111111 fbff
b: 1111111111111110 7fff
a: 1111111101111111 ff7f
Top rt: 1111111111101111 ffef
top lft:1111111111011111 ffdf
this gives 2^12 combinations or 4096
As you can see, a zero represents the button being
pressed, and a one is a "no press". To use this, just
set the correct bit from the chart above, and have
your controller jump on the correct combination.
The SNES controller pinouts[noparse]:([/noparse]from gamestation X)
/ 7 6 5 | 4 3 2 1 |
( o o o | o o o o |
\___________|________________|
pin description wire color
1 +5v white
2 data clock yellow
3 data latch orange
4 data line red
5 N/A
6 N/A
7 ground brown
To use this, just hit the data latch w/ a 12us pulse
to latch the parallel bits, and then reel them in on
the data line using SHIFTIN on the BSII, and its as
easy as that. The mode that I used to real in the
bits for the chart above was: mode 0, or MSBPRE.
You can also check out Al Williams's book,
Microcontroller Projects w/ Basic Stamps, page 179,
Expanding I/O. I hope all of that will help!!!!
--- Chris Savage <knight_designs@y...> wrote:
> --- acetoel <nik@i...> wrote:
> > Hello everybody,
> a
> > BS2 and a PS1
> all
> Aceto,
> figured it out yet?
> Chris Savage
> Knight Designs
> (607) 535-6777
> Do you Yahoo!?
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
Do you Yahoo!?
> a long while ago i hacked a super nintendo pad and
> it
> the
> ago:
Very detailed. Thank you! I happen to have a few of
those lying around the house! ;-)
Knight Designs
(607) 535-6777
Do you Yahoo!?
The proyect is working okey. I have the interfase ready, and now I'm
optimizing the code. In a very near future, two weeks I'm starting to
develop an interfase between a BS2 and a Sony Playstation Memory Card. It
uses the same protocol as the Controller, and you have more than 128KBytes
to storage data.
I though nobody remembered my proyect.
If you want the code, let me know that
Ezequiel
Sent: Thursday, September 12, 2002 12:25 PM
Subject: Re: [noparse][[/noparse]basicstamps] BS2 and Sony Playstation Joypad communication
> > Hello everybody,
> > BS2 and a PS1
> Aceto,
> figured it out yet?
> Chris Savage
> Knight Designs
> (607) 535-6777
> Do you Yahoo!?
> Hello,
> to storage data.
Yes Ezequiel, I would be interested in seeing the code
for how you have accomplished this interface with the
memory card. And what you have for the controller
too, if you don't mind sharing. I am interested for
NON-Commercial use.
Knight Designs
(607) 535-6777
Do you Yahoo!?
