Communication Buffer??
Hello All,
I'd like to glean some advise from all of the experience
represented here. I have a project involving two BS2's relaying machine
status back and forth to each other - communication is two-way. Neither
BS2 knows when the other will "say" or transmit something, the
communication is as needed, not at any given time or timing. My question
is: Should I use a programming loop with the SERIN command inside a
time-out loop and just check for something to be received often? or, Should
I have some kind of memory buffer between the transceiver and the BS2 to
hold received data until the program asks for it? What techniques have you
used and how have they worked?
Thank You,
Tim
Timothy Medema
CrystaLite, Incorporated
3307 Cedar St. (425) 745-6000 800-666-6065
Everett, WA 98201 Fax: (425) 257-0232
www.crystaliteinc.com
<mailto:timm@c...>timm@c...
The information transmitted is intended only for the person or entity to
whom it is addressed and may contain confidential and/or privileged
material. Any review, retransmission, dissemination or other use of, or
taking of any action in reliance upon, this information by persons or
entities other than the intended recipient is prohibited. If you received
this in error, please contact the sender and delete the material from any
computer.
Thank You,
Tim
Timothy Medema
computer.
for handshaking. It's a lot faster checking a bit than waiting until
data arrives, if it does.
#1 -- I want to send on line 3
#2 -- Check line, sees request, use 4 to say ok, send.
This is way you can sychronize the data without it being real time.
My 2 cents.
-Martin Hebel
Southern Illinois University
--- In basicstamps@y..., Timothy Medema <timm@c...> wrote:
> Hello All,
machine
Neither
question
or, Should
BS2 to
have you
> Thank You,
> Tim
> Timothy Medema
entity to
of, or
received
from any
> computer.
Thanks for your reply. Obviously you're dealing with a
communication rookie, could you point me to something (tutorial maybe) that
I could read to educate myself, or examples?
Your input is worth much more than 2 cents,
Tim
At 08:54 PM 7/26/2002 +0000, you wrote:
>If you aren't absolutely limited to only 2 lines, 2 more can be used
>My 2 cents.
>-Martin Hebel
> > Hello All,
>machine
>Neither
>question
>or, Should
>BS2 to
>have you
> > Thank You,
> > Tim
> > Timothy Medema
>entity to
>of, or
>or
>received
>from any
> > computer.
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Timothy Medema
computer.
Also, is any additional hardware involved, or just the bit check
at that particular pin?
Tim
>My 2 cents.
>-Martin Hebel
> > Hello All,
>machine
>Neither
>question
>or, Should
>BS2 to
>have you
> > Thank You,
> > Tim
> > Timothy Medema
>entity to
>of, or
>or
>received
>from any
> > computer.
I agree with Martin, if you can run two extra lines and use two extra
pins on each BS2, then hardware handshaking is by far the easiest way
to go. The SERIN and SEROUT commands have options for this kind of
flow control built in. Refer to the Stamp manual. Also I have a
tutorial on this posted at:
http://www.emesys.com/BS2rs232.htm#MasterSlave
The only extra hardware you need is the two wires, and it is a good
idea to put a resistor (~500 ohm) in series with the stamp pins at
the ends of the wires, for protection.
-- best regards
Tracy Allen
http://www.emesystems.com
mailto:tracy@e...
>Hello Martin,
>Tim
>>My 2 cents.
>>-Martin Hebel
>> > Hello All,
>>machine
>>Neither
>>question
>>or, Should
>>BS2 to
>>have you
>> > Thank You,
>> > Tim
>> > Timothy Medema
>>entity to
>>of, or
>>or
>>received
>>from any
>> > computer.
>Timothy Medema
>computer.
My application is wireless using the Parallax 27997 transceiver
modules at each end. Can I use a handshanking technique in this situation
also?
Thank you very much,
Tim
At 02:46 PM 7/26/2002 -0700, you wrote:
>Hi Tim,
> -- best regards
> Tracy Allen
> mailto:tracy@e...
> >Hello Martin,
> >Tim
> >>My 2 cents.
> >>-Martin Hebel
> >> > Hello All,
> >>machine
> >>Neither
> >>question
> >>or, Should
> >>BS2 to
> >>have you
> >> > Thank You,
> >> > Tim
> >> > Timothy Medema
> >>entity to
> >>of, or
> >>or
> >>received
> >>from any
> >> > computer.
> >Timothy Medema
> >computer.
timm@c... writes:
> also?
Tim, Martin and Tracy are a lot smarter than I am, but I use an "addressable"
serin/serout routine with both my RF (Parallax also) and my Sony Remote
Control programs. Theirs is probably a better overall solution but if you
get desperate I'll share.
Sid
Don't sell yourself short, we can all learn from each other -
everyone has something to contribute! Please share your "addressable"
technique.
Thank you,
Tim
At 06:24 PM 7/26/2002 -0400, you wrote:
>In a message dated 7/26/02 18:01:23 Eastern Daylight Time,
>timm@c... writes:
> > also?
>Sid
timm@c... writes:
> technique.
The "addressing" is really nothing more than utilization of the 'wait"
modifier. If you write
serin 16, N9600, 500, nodata, [noparse][[/noparse]wait("sid"), data]
it will sit there forever until it gets something prefaced by "sid". For
example,
serout 16, N9600, [noparse][[/noparse]"sid", data]
is the only transmission the serin would respond to. So in essence it is
"addressable". I have a program that reads and decodes the signal from a
Sony Universal Remote, which produces 16 variables. I write
if s(1) = 2 and s(2) = 2 and s(3) = 4 and s(4) = 2 then xmit
goto begin
xmit
goto begin
nodata
goto begin
Serin will wait 500ms, then jump to nodata, which sends it back to begin, and
the process starts all over.
Does any of this help ?
neither mine nor Tracy's answers will suit, they relied an 4 lines.
Without a buffer, it get's a little rough. Sid's idea to make it
addressable helps ensure you are ready from correct incoming data,
but the need is still there to sit and wait for it.
Onc option I've used before is when the transmitter is ready to send,
have it send a character repeatedly. Eventually, the reciever will
be in a condition to catch that one character, respond, then the
transmitter can send the entire packet knowing the reciever is
listening.
Attention:
ready_bit = 1
'keep sending 1 and waiting for reply
SEROUT pin,baud,[noparse][[/noparse]1]
SERIN pin,Baud,500,Attention,[noparse][[/noparse]DEC ready_bit] 'timeout repeats this
routine
'repeat until returning data (bit=1)
If ready_bit = 0 Then Attention
GotAttention:
SEROUT pin,baud,[noparse][[/noparse]importantdata]
Untested code for transmitter, but doesn't look too far off....
-Martin
--- In basicstamps@y..., Tracy Allen <tracy@e...> wrote:
> Hi Tim,
extra
way
> -- best regards
> Tracy Allen
> mailto:tracy@e...
> >Hello Martin,
maybe) that
> >Tim
used
until
time.
> >>My 2 cents.
> >>-Martin Hebel
> >> > Hello All,
experience
relaying
> >>machine
> >>Neither
My
> >>question
inside a
often?
> >>or, Should
the
> >>BS2 to
techniques
> >>have you
> >> > Thank You,
> >> > Tim
> >> > Timothy Medema
> >>entity to
privileged
use
> >>of, or
persons
> >>or
you
> >>received
material
> >>from any
> >> > computer.
> >> basicstamps-unsubscribe@y...
Subject and
> >Timothy Medema
entity to
of, or
received
from any
> >computer.
some work and respond. Both stamps would do something like this:
wait for a special token
do any required processing
send result
send special token
In order for this to work, you would need to establish a mechanism to determine
which stamp should talk first. You could do a master/slave kind of thing where
the programs would be different (so one stamp would always talk first), or you
could use a random timeout kind of algorithm and let the stamps themselves
determine who's first (the programs could be the same in this case)
The stamps would continuously pass the token back and forth, whether or not any
useful data needed to be sent.
I have a really bad headache, and I probably shouldn't have tried to answer [noparse]:)[/noparse].
I hope you find something useful in my answer though...
Stan
> Hello All,
> Thank You,
> Tim
> Timothy Medema
> computer.
I didn't realize this was a radio application either. Here are a
couple more cents to add to what others have said...
If you do want to use a buffer, which would certainly help, then the
MAX3100 is a UART that has an 8 byte buffer as well as a pin that
signals that data is available.
Another kluge option is to generate a BREAK signal on the transmit
stamp when it wants to talk to the other. The BREAK simply keys the
transmitter ON for a second, long enough for the receiving stamp to
get around to checking its data input pin (which for this scheme to
work has to be one of the p0 to p15, not p16.) Then when the BREAK
ends, the ascii communication can begin. I've used that with a modem.
Or, if the data is not time critical, and if both Stamps have clock
chips, then they can agree to exchange data at some regular
interval... synchronize watches please.
Of course, there is always the problem with radio--bad data--when the
signal is weak. In which case you still need some kind of
'addressable' scheme and maybe even a packet scheme with checksums to
verify the data. The limit of this is the purchase of a TNC or a
genuine radio modem that has all of the packet creation and
verification built in.
-- best regards
Tracy Allen
mailto:tracy@e...
Thank you for your responses over the weekend. First off, my apologies for
not making it clearer that my application is wireless! Second, I
appreciate all of this input, and as a rookie will have to take some time
to study and try each of the techniques that you present. Most likely,
I'll be parts of each of them rolled together in the end.
Sid, Yes your "addressable" idea helps alot. Maybe in a single device
control situation, this could also be used to identify what the incoming
data is: If preface is "Bat", then the data that follows represents the
battery condition or if the preface is "Pos" then the data that follows
represents the position of some such mechanical beast or something. Thank
you for including the code example.
Martin, This sounds like a good and simple way of each "end" getting the
others attention. Thank you for including your code example.
Stan, Your ideas too are appreciated. It helps for me to see the concept
steps written out like you did. I hope you have gotten rid of your
headache and are feeling better.
Tracy, Thank you for including the Maxim UART part number for me to look
into, I'll be downloading the data sheets today. Have you used this chip
and would you have some BS2 code available? I'm not sure that I understand
the BREAK signal idea - it implies that the receiving end "sees" or has an
output change state when the transmitter on the other end keys up. Am I
understanding this correctly? If so, that could be helpful.
To All, I know I'm asking alot, but like I said, I'm a rookie - what type
of error or sum checking schemes have you come up with and would you share
some code examples?
Thanks again,
Tim
At 12:13 PM 7/27/2002 -0700, you wrote:
>Hi Tim,
> -- best regards
> Tracy Allen
> mailto:tracy@e...
timm@c... writes:
Just remember the the "addresses" are case-sensitive. "Bat" is not the same
as "bat".
Sid
Tim
At 11:35 AM 7/29/2002 -0400, you wrote:
>In a message dated 7/29/02 11:03:10 Eastern Daylight Time,
>timm@c... writes:
>as "bat".
>Sid
Hi Tim,
You can find some code posted at
<http://www.emesystems.com/BS2IrDA.htm>. The tutorial there talks
about the IrDA capabilities of the MAX3100. However, the code will
work also with standard wired connection. Change the configuration
word to, say, E04D, instead of C08D; that sets wired connection
(instead of IrDA), 2 stop bits (instead of 1) and 8-byte FIFO
enabled. Study the data sheet to understand the options for the
"write configuration" command. You may want to use an inverter
between the UART and your radio. I think Al Williams too has some
MAX3100/stamp information on his web site.
BREAK is a standard notion in ansychronous serial communication. An
RS232 line normally rests at negative something volts, and then
pulses positive briefly to send bytes of data. The data stream is
punctuated often with stop bits, so the RS232 line never stays at a
high level for very long. BREAK means bringing the line active on
purpose for a time much longer than the normal byte period. It might
be 0.3 second or longer. That would mean you would simply key ON
your transmitter (HIGH 5[noparse]:p[/noparse]ause 300). The receiver would come around
periodically and look to see if its receive line is active. If so,
stays at that point in the program until the line again goes low. At
that point, an exchange of data can commence. In the nature of short
range radio communication with low power AM, the receiver will detect
a lot of noise bursts when the transmitter is off, so there has to be
a verification step. Another idea that came up in this tread was for
the transmitter to simply send a certain byte repeatedly until the
receiver sends back a handshake.
-- best regards
Tracy Allen
mailto:tracy@e...
careful: these parts are very difficult to actually buy!
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller
http://www.al-williams.com/awce/pak1.htm
> >.. MAX3100.. Have you used this chip
appreciated. I'll check with Al Williams too and get reading!
Tim
>Hi Tim,
> -- best regards
> Tracy Allen
> mailto:tracy@e...
I used to avoid all those wonderful MAXIM parts, because they were so
hard to obtain. But the e-commerce connection direct from
http://www.maxim-ic.com works great. It is a bit of a pain to sign
up for at first, but well worth it if you want their esoteric stuff.
For example, the MAX3100EPD is in stock now. Also, Maxim is very
generous with samples if you only need a couple for evaluation or for
a hobby project.
-- Tracy
I have both sides of that story as well and was even told by a
national parts distributor not to implement Maxim parts into a production
product due to inconsistencies in availability of those parts. I also have
ordered samples from Maxim and find them to be very generous.
Tim
At 11:29 AM 7/29/2002 -0700, you wrote:
> >http://www.wd5gnr.com/suart.htm is a MAX3110 UART used with a Stamp. Be
>a hobby project.
> -- Tracy
Surprise, surprise. It happens that all of my Maxim parts here were
ordered via their samples phone numbers, and even via their badly
designed website. The same goes for the Dallas end of their site. Some
national parts vendors, do not like Maxim because those parts that the
company makes are, well, strange. Companies such as Mouser, and Digikey,
and Jameco, love Maxim for the same reasons that have just been
espoused. Everyone is entitled to an opinion, what happens once you've
heard the one supplied by the other guy, is up to you.
Gregg C Levine hansolofalcon@w...
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke."· Obi-Wan Kenobi
(This company dedicates this E-Mail to General Obi-Wan Kenobi )
(This company dedicates this E-Mail to Master Yoda )
> From: Timothy Medema [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wZD8kE29Nki_9-UHAzmLKhBvhLTzX6lh3hdpDIPdx3oo5cLFUlnfNHXfSx9xnVuphUF52BBK_lXzbMy2Dw]timm@c...[/url
> Sent: Monday, July 29, 2002 3:20 PM
> Subject: RE: [noparse][[/noparse]basicstamps] Re: Communication Buffer??
> Al and Tracy,
a
production
have
> Tim
Stamp. Be
> >a hobby project.
> > -- Tracy
and
and Body of
