Wireless question — Parallax Forums
Wireless question
edited 2002-07-25 01:50 in General Discussion
Hello all,
I have a project which I would appreciate any input on...
I would like to use a stamp to control a motor and its operational state
based on inputs from two substations. If a signal is received from
substation A But not substation B, then the motor @mainstation would run for
10 additional minutes, then if no other signal is received shut off. If
during that 10 minute period A reactiveates, then the kill process is
stopped. If during the 10 minute period a signal is received from
substation B, then the motor is stopped immediately.
The killer is that the substations/mainstation are a half mile apart. I
have used buried cable in this area before, but have quit because prarie
dogs/gophers always chew the line.
I hope this gives a fairly clear picture of what I would like to accomplish,
but would be happy to answer any questions.
Some current considerations
...How to cover the distance wirelessly?
...How to distinguish between Stations A and B and perhaps an additional
station later.
...The "best" overall design.
Substation A <
1/2 mile
>(Mainstation)<
1/2
mile
>Substaion B
I am in the preliminary stages of thinking through this.. i.e. nothing is
set in concrete so any thoughts would be appreciated.
Thanks for your assistance.
Vince
    edited 2002-07-18 20:12
    For Vince
    I can write a program that will accomplish what you want, but as you point
    out, interstation communication is the problem. What is the topography
    between the main and sub-stations ? Where do A and B get their power
    from ? Are "relay" stations feasible ?
    RF equipment to cover that distance is available but quite expensive.
    I have written several programs using RF and IR for remote control of relays
    but all for shorter disances.
    Sid
    edited 2002-07-18 20:31
    Sid,
    Thanks for the reply.
    You are correct in that the communications part of the equation may be the
    toughest to whip.
    The area between the station/substations are relatively flat and level. With
    few to no obstructions. Power is available at all stations. Relay stations
    would not be feasable for a number of reasons.
    Thanks again.
    VF
    From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9vOYRCGp0SBS-D5LepWdeTnxZH1gmlaays8hVT4-0VD-XKy-oz2zGTm5il5SNvxvbdR8OYAF]Newzed@a...[/url
    Sent: Thursday, July 18, 2002 2:13 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Wireless question
    For Vince
    between the main and sub-stations ? Where do A and B get their power from ?
    Sid
    edited 2002-07-21 09:41
    Vince,
    A few things came to mind about the wireless solution when I read
    your post. It's fairly trivial really to send low speed data over a
    distance of a mile or so, the only question is how fancy you want to
    get which ultimately dictates how much money you plan to spend. One
    thing you might try if you plan to use a basic stamp is to pick up a
    couple TNC's (Terminal Node Controller) like what is used for data
    communication in the amateur (HAM) radio scene. Check out eBay and
    do a search for 'TNC' or maybe 'packet radio'. A search for 'packet
    radio' found this TNC for around 20-30 bucks:
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=1366706725
    You'd then need a couple transceivers and antennas to hook em up to
    and a frequency to operate on that would be approved by the FCC for
    such a purpose (I'd recommend the 433mhz range like the RF modules
    from Parallax). Most likely you'll be in violation of some FCC rule
    or regulation for even attempting this without a license, but if it
    doesn't cause any interference to a commercial entity or government
    agency you won't have any problems. After all this you'll have to
    play around with getting the stamp to talk to the TNC which should be
    fairly trivial since it has a serial interface anyway. You could
    easily cover several miles this way, especially if you had decent
    output power on your transmitters and good antennas.
    Another solution that may work is just modifying the RF modules that
    Parallax has. The ones with the wire antennas look promising. Looks
    like you could remove the wire antennas and probably intall a BNC,
    UHF, or N connector. The fixed antenna modules might even have
    removable antennas already. In either scenario, once you have a
    connector in place, you can run it directly to an external anteanna
    with some coax or through an amplifier first if you need more power.
    This has probably already been done or attempted by someone out
    there, maybe asking around on this list or searching the web would
    yield some results.
    Good luck with the project. Remember this is all theoretical!
    --- In basicstamps@y..., "Fell, Vince" <vince.fell@t...> wrote:
    > Hello all,
    state
    would run for
    off. If
    is
    apart. I
    prarie
    accomplish,
    additional
    > station later.
    > Substation A <
    1/2 mile
    >(Mainstation)<
    1/2
    > mile
    >Substaion B
    nothing is
    > Vince
    TNCs are fairly low speed devices - most of the ones
    that are being resold for cheap are 1200 baud units.
    If that is acceptable then the next question is what
    radios and frequencies are going to be used. If
    reliability is a concern, 433MHz may not be the ideal
    frequency to use as the US Government and licensed
    Amateur Radio operators have precedence to the range
    of frequencies in that neighborhood (420-450MHz). They
    may not welcome your presence as packet activity is
    not used in that part of the frequency spectrum. (Long
    haul Single Sideband Voice is normally operated here.)
    Alternatives - 49MHz walkie talkies?
    From a packaging perspective, things start to get
    kludgy as a TNC may be as small as a pack of
    cigarettes but are often much bigger, about the size
    of an old Hayes modem. Combine that with a radio and
    you may decide to stick with an already built,
    integrated, and neatly packaged part 15 solution that
    could support data rates up to 19.2Kbps.
    The best way to increase range for a part 15 device is
    to mount the antennas up as high and in the clear as
    possible. Using beam antennas will decrease the amount
    of unintended interference; both transmitted and
    received along the signal path to both of your
    stations. In doing so, though, you may be in violation
    of FCC rules. Just a word of warning. It is possible
    that you can do this and never bother anyone or get
    caught in the act (just not in LA!).
    Kevin K Asato
    KC6POB
    --- tilrock <tbanez@h...> wrote:
    > Vince,
    > speed data over a
    > fancy you want to
    > plan to spend. One
    > is to pick up a
    > used for data
    > Check out eBay and
    > search for 'packet
    > to hook em up to
    > by the FCC for
    > the RF modules
    > of some FCC rule
    > license, but if it
    > you'll have to
    > TNC which should be
    > anyway. You could
    > you had decent
    > RF modules that
    > promising. Looks
    > intall a BNC,
    > might even have
    > once you have a
    > external anteanna
    > need more power.
    > someone out
    > the web would
    > yield some results.
    > theoretical!
    > > Hello all,
    > input on...
    > its operational
    > state
    > is received from
    > @mainstation
    > would run for
    > received shut
    > off. If
    > the kill process
    > is
    > is received from
    > immediately.
    > a half mile
    > apart. I
    > have quit because
    > prarie
    > would like to
    > accomplish,
    > perhaps an
    > additional
    > > station later.
    > > Substation A <
    1/2
    > mile
    >(Mainstation)<
    1/2
    > > mile
    >Substaion B
    > this.. i.e.
    > nothing is
    > appreciated.
    > > Vince
    > Text in the Subject and Body of the message will be
    > ignored.
    __________________________________________________
    Do You Yahoo!?
    Yahoo! Autos - Get free new car price quotes
    http://autos.yahoo.com
