TAB Robot Kit motors — Parallax Forums
edited 2002-07-19 02:12 in General Discussion
Hi Charles,
I sent you an email about an hour ago - I guess you haven't see it yet.
If the motor can turn in one direction, it will be able to turn in the
other. It sounds like the motor driver somehow got burned out.
The motors themselves were specially wound for the application and while you
should be able to find replacements, it may be somewhat difficult. Note
that you will have to change both motors because you will have an unbalanced
situation where the two motors will be running at different speeds with
different torque outputs.
Check out my email and let's see what we can do to get you back on the road.
myke
Sent: Thursday, July 18, 2002 12:31 AM
Subject: [noparse][[/noparse]basicstamps] TAB Robot Kit motors
> I bought a TAB robot kit about three weeks ago, and it has been working
> perfectly. Yesterday, however, one of the motors decided to move in one
> direction only. That is, it will go backward, but not forward. I checked
> the voltages going to the motor, and they do indeed change polarity when
the
> direction is changed. I also checked that the wires and connector are
okay.
> Does anybody know what kind of motors are used in this kit? Can I buy
them
> at a local hobby shop or an online source?
> I would like to use the identical motor, since I don't want to change the
> mounting and gearing.
> Thanks for any info you can provide.
> -Charles
    edited 2002-07-18 05:31
    the voltages going to the motor, and they do indeed change polarity when the
    direction is changed. I also checked that the wires and connector are okay.
    Does anybody know what kind of motors are used in this kit? Can I buy them
    -Charles
    edited 2002-07-19 00:07
    Dear Myke:
    You wouldn't happen to be the author of PC Ph. D. would you? If by chance you
    are I just wanted to commend you on your work!! I use your book all the time and
    i find it to be a very valuable reference/ resource in my collection!
    -=Randy Knutson
    myke predko <myke@p...> wrote: Hi Charles,
    myke
    To:
    the
    okay.
    them
    > -Charles
    from the same email address that you subscribed. Text in the Subject and Body of
    Do You Yahoo!?
    Yahoo! Autos - Get free new car price quotes
    Check to see that your tire is not rubbing the chassis of the bot.
    My robot had this same problem until I added two small washers on
    the axle between the tire and the axle holding bracket.
    Hope this helps,
    Joe
