BS2p data capture
Archiver
I am trying to capture data from BS2p using serout. I like to use
applications like hyperterminal or Matlab to capture the data. But it
does not work with any application except BS2p itself and Stamp Plot.
I like to know what format BS2p outputs data and if there is anyway
of getting that data through other applications.
writes:
It is quite easy to capture data from a Stamp into Excel, if you are familiar
with Excel. If you are interested contact me off-line.
Sid
doing it manually right now...i use stamp plot to save the data and
then import it into excel...
what i am interested in doing is a real time plotting of data...i
think i can do that with matlab...i am not sure if its possible in
excel...i like to know how one can do it
--- In basicstamps@y..., Newzed@a... wrote:
> In a message dated 7/17/02 16:44:24 Eastern Daylight Time,
kambms@y...
> writes:
But it
Plot.
anyway
are familiar
> Sid
here?
kambms <kambms@y...> wrote: you mean you can capture data directly into
excel from bs2?? i am
kambms@y...
> writes:
But it
Plot.
anyway
are familiar
> Sid
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
Do You Yahoo!?
Yahoo! Autos - Get free new car price quotes
additional specifics contact me off line.
Format the data in Stamp the way you want it captured, i.e., separate numbers
by spaces, commas or tabs. Excel has to have a delimiter in order to put the
data in columnar form.
Once you have your data formatted, exit Stamp, go to Excel and create a file
- for example - testdata.txt. Open a page in Excel and pout your name or
something at the top. When you save the file be sure to save it as a .txt
file. Close Excel.
Go to your Hyperterminal program, which should be setup "Direct to Com2",
click on Transfer/Capture Text. Enter the path to your Excel file, for
example, C:\Office20\Office\testdata.txt, then click on start.
When the blank screen appears, start Stamp. Data being captured will appear
on the screen. When you have all the data you want, click on
Transfer/Capture Text/Stop. Exit Hyper.
Go to Excel, open testdata.txt, and assuming you have a fair knowledge of
Excel you should be able to format the data into columns, specifying Text
instead of General for the numbers. Otherwise you will lose leading zeros
which may or may not be important.
That's a brief resume of the process. It works beautifully, just have a
little patience the first time you try it.
Sid
hyperterminal. I got a RS-232 cable connected from the BS2 to COM1. I
configured Hyperterminal. But i dont see it coming.
> This is for those on the list who requested more info. If you need
separate numbers
to put the
create a file
name or
a .txt
> file. Close Excel.
Com2",
for
will appear
knowledge of
specifying Text
leading zeros
have a
> Sid
writes:
> That sounds good. But i am not able to get the BS2 into
For kambms
For this purpose couldn't you connect your Stamp to your PC via the serial
cable to Com2. Serial cable to Com2 is, I think, the normal method of
connecting a Stamp to a PC.
Sid
straight-through RS-232 cable. You need a direct connect cable or
another term for it is null-modem cable. A null modem cable has the
number 2 and 3 wire twisted. In this way, the data going out from
the Stamp (write) goes into the read pin on the PC. Of course, I am
assuming you are using a straight-through serial cable. If you are
using a null-modem cable then I am not sure what the problem is.
I
need
> separate numbers
order
> to put the
> create a file
> name or
as
> a .txt
> > file. Close Excel.
to
> Com2",
file,
> for
> will appear
> knowledge of
> specifying Text
> leading zeros
> have a
> > Sid
use Serout to use different baud rates if needed. I use Hyperterminal
and Tera Term Pro all the time with the basic stamp. Check your cable
and comm settings.
If you want to plot real time serial data from the basic stamp then
buy StampPlot Pro from Selmaware. The only way to capture serial data
if you ask me. It is on sale for $39.99 right now.
www.selmaware.com
Jason
it
Plot.
internet, go to http://www.lennard.net.nz/ click on electronics, then A to
D. Theer you will find my first ever experiment with A to D conversion and
data logging - including using Excel to display a graph of the logged data.
cheers,
Ben, Windy Wellington, New Zealand.
Ben Lennard, NCEE, Dip EE
Web Hosting and Electronics R&D
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
"To the optimist, the glass is half full. To the pessimist, the glass is
half empty. To the engineer, the glass is twice as big as it needs to be."
No animals were harmed in the transmission of this email, although the
Dog next door is living on borrowed time, let me tell you! Those of you
with an overwhelming fear of the unknown will be gratified to learn that
there is no hidden message revealed by reading this warning backwards.
> From: Newzed@a...
> Reply-To: basicstamps@yahoogroups.com
> Date: Wed, 17 Jul 2002 17:43:03 EDT
> Subject: Re: [noparse][[/noparse]basicstamps] Re: BS2p data capture
> file. Close Excel.
> Sid
> of the message will be ignored.
The discussion is good timing for a free software program we will announce
today.
By noon PST you will have a solution!
Sincerely,
Ken Gracey, Parallax Inc.
New! Microcontroller Application Cookbook Volume 2
BASIC Stamp circuits and code for motors, power supply, sensors of all
types, networking, solar power and proximity
$29.95 at http://www.parallaxinc.com/mac
Message: 6
Date: Wed, 17 Jul 2002 14:12:46 -0700 (PDT)
Subject: Re: Re: BS2p data capture
I would like to know how you do that capture too. Is it something you can
post here?
into excel from bs2?? i am
kambms@y...
> writes:
But it
Plot.
anyway
are familiar
> Sid
