Javelin stamp in Boe Bot
Has anyone replaced the Basic stamp with the Javelin stamp into Boe Bot?.
Parallax says that
it is pin-by-pin compatible and it works, but in a separate discussion area
it seemed that a couple
of things had to be done, like potentially adding a separate power source
just for the servos because
the Javelin needs a higher voltage than the Basic stamp and when the servos
kick in they cause the
Javelin to reset because they draw to much current away.
If you have done this successfully or work for Parallax and know the
details, could you please let us know
what you have to do?
Thanks in advance,
Juan
Juan Ardura
Principal Software Engineer
Lucent SpringTide Group
Three Clock Tower Place
Suite 200
Maynard, MA 01754 USA
Parallax says that
Thanks in advance,
Juan
Juan Ardura
Suite 200
