Servos, basics of BASIC Stamps — Parallax Forums
edited 2002-07-17 07:13 in General Discussion
Hi, I've been looking at BASIC Stamps and robotics for about a day
now and I'm wondering about a few things:
1. Where can I find more info? (web, books, etc? Specific titles and
urls?)
2. How does the BASIC Stamp IC connect to the RC Servo?
3. What's a good, cheap Servo and where can I get it? (small, not too
strong)
4. How much will it cost to make a simple Stamp-controlling-a-servo-
bot?
Thanks!
    edited 2002-07-16 02:48
    If you want free, download all of the documents from Parallax, especially
    the BoE and BoEBot stuff -- including how to control a servo.
    The Nuts & Volts of Basic Stamps books covers a much broader scope -- not
    just robotics. These are also a worthwhile investment.
    As far as servos, the Futaba S148 is about the easiest to hack -- you need a
    screwdriver and an Exacto knife.
    > urls?)
    > strong)
    > bot?
    edited 2002-07-17 04:22
    1. Look through the documentation at www.Parallax.com . Search the archives
    of this list at yahoo. Search the web - there are too many urls to list. Ask
    question here.
    2. There a three leads on a servo. You need to work out which is which. One
    is a positive power lead, one is a ground and one is a control lead. The
    positive power lead goes to the positive terminal of a 4.8V-6V power
    source(do not use the +Vdd on the stamp). The ground lead goes to the
    negative terminal of the same power source, and also to the ground pin of
    the basic stamp(labelled Vss). The control pin goes to one of the Stamps
    input/output pins, (usually labelled 1-16)
    3. Just go to your local hobby shop and get the cheapest servo. Hitec are
    cheap. Towerhobbies or servocity.com sell cheap hitec servos for about
    $10US.
    4. You need the servos, the stamp, a stamp carrier board, a
    powersupply(batteries or plug adapter), and some sort of physical structure
    for the robot. The minimum would probably be 2 servos(for two wheels),
    stamp, stamp carrier board and some wheels, batteries and wood. You could
    probably do it for around about $100US
    Paul
    >From: "scallion20022002" <yahoo_spam@s...>
    >Reply-To: basicstamps@yahoogroups.com
    >Subject: [noparse][[/noparse]basicstamps] Servos, basics of BASIC Stamps
    >Date: Tue, 16 Jul 2002 01:12:48 -0000
    >urls?)
    >strong)
    >bot?
    >Thanks!
    >from the same email address that you subscribed. Text in the Subject and
    >Body of the message will be ignored.
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    _________________________________________________________________
    Send and receive Hotmail on your mobile device: http://mobile.msn.com
    I would highly recommend the Boe-Bot Full Kit from Parallax Inc.
    http://www.parallaxinc.com
    They are currently back ordered... but definitely worth the wait. If you
    are just starting out... this will be perfect for you.
    Also... referring to your question #3... don't forget that unmodified servos
    (like you buy at the hobby store) do not have continuous rotation and must
    be "hacked" in order to use them as drive motors.
    - Brice
    Sent: Monday, July 15, 2002 8:12 PM
    > urls?)
    > strong)
    > bot?
    > Thanks!
