Many Stupid questions
Archiver
Hello from Gregg C Levine
I've got a stupid question to ask. And it's probably one which has been
asked before, but not by me. Can the BASIC stamps be damaged by the mere
act of soldering near them? I left mine in its carrier board while I was
soldering in place the power supply (regulated) wires, and now I am
getting errors from the stamp program. This is a Stamp One. One of the
errors states that it can't find the device, it actually says, "ERROR
Hardware not found". But the funny thing is that it would say that, when
it was having problems with the power supply connections being loose on
the pins, for example, that was before I did that to the carrier board.
Or even when I had problems with the homebrewed programming cable. Also
is there a proper setting in the BIOS of a PC for the parallel port?
Normally I am a better worker then this, but I was actually in a hurry
this time.
Gregg C Levine hansolofalcon@w...
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke."· Obi-Wan Kenobi
(This company dedicates this E-Mail to General Obi-Wan Kenobi )
(This company dedicates this E-Mail to Master Yoda )
this time.
Mike.
Sent: Sunday, July 14, 2002 7:57 AM
Subject: [noparse][[/noparse]basicstamps] Many Stupid questions
this time.
"Use the Force, Luke." Obi-Wan Kenobi
First thing I checked. It isn't. I even dug up a standard 9 volt
battery, and attached it to the clips, and checked to see if it would
work. Same thing happened.
> From: Mike van der Hulst [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Ek9tp_-yMtBTJgBNl6gKcJaHDI10v8z74hTDzGWeaTep9gPGOzrq6DsMHBFh6O7I56MjhoV2JneNMLwsgwMNlq6QVg]mike.van.der.hulst@h...[/url
> Sent: Sunday, July 14, 2002 4:48 AM
> Subject: Re: [noparse][[/noparse]basicstamps] Many Stupid questions
> Maybe the voltage is to low ?
> Mike.
> From: "Gregg C Levine" <hansolofalcon@w...>
been
mere
was
when
on
board.
Also
> this time.
and
and Body of
