Need help with Line Following and Object Detection
Hi...
I got the Line Follower Module for my Boe-bot and it is following a
black line consistently. I need to now incorporate object detection
with the line follower and was wondering how i can do that.
Basically the task i have to do is to have the boe-bot follow a black
line and come upon four spaces that represent parking spaces. now
three of these four spaces will have objects occupying them and the
boe-bot should be able to detect what spaces have objects in them,
avoid those spaces, and follow a black line into the space with no
object in it and park.
i am thinking about either using the Whiskers that i have from
purchasing the Whisker kit to serve as the sensor to detect if the
boe-bot sees a parked car but i'm thinking this might be difficult if
the spaces are pretty close to each other. also i'm considering using
infrared detectors to detect objects if the parked cars are farther
away from the boe-bot. my question is which would be the best and
easiest to go with? i have no experience programming the BS2 and want
to keep it as simple as possible and incorporate the code to do the
object detection into the code i got when i purchased the Line
Follower module. i've looked at some code that came with the Whiskers
kit called Whisker.bs2 and some in the Robotics manual for use with
infrared and am confused.
what code would you suggest i use? and where in the line follower code
would i put it so that it could handle both needs? I've tried
contacting the Tech Support at Parallax, but they just tell me to look
at the manual that came with the boe-bot kit and obviously i've
already looked at it before i asked. them. I need specifics!
here's the code i'm using now to follow the black line and i want to
put the object detection code into here to run the boe-bot for both
capabilities:
' { $STAMP BS2 }
[noparse][[/noparse] Program Description
' This program is designed to run line follower
contests where the
BOE-Bot will
' start and stop on a "T" in the track. It implements
a controlled
start feature
' using the BOE Reset button. Pressing the Reset
button starts the
BOE-Bot.
[noparse][[/noparse] Revision History
' 01 DEC 2001 - Version 1.0
[noparse][[/noparse] I/O Definitions
LMotor CON 13 ' servo motor connections
RMotor CON 12
[noparse][[/noparse] Constants
LEDon CON 0 ' LF LEDs are active low
LEDoff CON 1
WLine CON 0 ' white line on black
field
BLine CON 1 ' black line on white
field
LFmode CON BLine ' set pgm for black line
MStop CON 750 ' motor stop
LSpeed100 CON 180 ' full speed
RSpeed100 CON 245
Speed075 CON 75 ' three-quarter speed
Speed050 CON 40 ' half speed
Yes CON 1
No CON 0
[noparse][[/noparse] Variables
temp VAR Byte
ledPos VAR Nib ' LED position in lfBits
lfBits VAR Byte ' line follower input bits
lastBits VAR Byte ' last LF input
steer VAR Nib ' steering control
onCourse VAR Bit ' on course flag
[noparse][[/noparse] EEPROM Data
RstValue DATA $FF ' $FF = no run
[noparse][[/noparse] Initialization
Run_Check:
READ RstValue, temp ' get reset value
temp = ~temp ' invert bits
WRITE RstValue, temp ' write inverted bits back
IF (temp) THEN Initialize ' run if inverted > 0
No_Run:
END ' low power mode
Initialize:
PAUSE 500 ' allow hand to release
OutL = %01111100 ' all LF LEDs off
DirL = %01111100 ' make pins outputs
lastBits = %00100 ' assume straight
onCourse = No ' we haven't run course yet
[noparse][[/noparse] Main Code
Main:
GOSUB Read_Line_Follower ' read the Line Follower
IF (lfBits <> %00100) THEN Check_End ' check for
middle sensor
onCourse = Yes ' -- has been on the course
Check_End:
IF (lfBits <> %11111) THEN Steer_Robot ' keep steering
if not at
end
IF (onCourse = No) THEN Straight ' still at start
IF (lastBits <> %00000 ) THEN At_End ' verify end of
course
Steer_Robot:
steer = NCD lfBits ' get highest "on" bit
BRANCH steer,[noparse][[/noparse]Off_Line, Hard_Right, Right, Straight,
Left, Hard_Left]
Save_Last:
lastBits = lfBits ' save last reading
GOTO Main
At_End:
PULSOUT LMotor, MStop ' stop motors
PULSOUT RMotor, MStop
Dirs = 0 ' turn off outputs
WRITE RstValue, 0 ' run again after Reset press
END
[noparse][[/noparse] Subroutines
Read_Line_Follower:
lfBits = 0 ' clear last reading
FOR ledPos = 2 TO 6
OutL.LowBit(ledPos) = LEDon ' turn the LED on
PAUSE 1 ' allow sensor to read
lfBits.LowBit(ledPos) = In9 ^ LFmode ' record the
sensor reading
OutL = OutL | %01111100 ' turn LEDs off
NEXT
lfBits = lfBits >> 2 ' shift bits to zero
index
RETURN
Off_Line:
lfBits = lastBits ' get last known position
GOTO Steer_Robot
Hard_Right:
PULSOUT LMotor, MStop + Speed075 ' full speed on left
PULSOUT RMotor, MStop ' reverse right motor
GOTO Save_Last
Right:
PULSOUT LMotor, MStop + LSpeed100 'full speed on left
PULSOUT RMotor, MStop - Speed050
GOTO Save_Last
Straight:
PULSOUT LMotor, MStop + LSpeed100 'both motors forward
PULSOUT RMotor, MStop - RSpeed100
GOTO Save_Last
Left:
PULSOUT LMotor, MStop + Speed050
PULSOUT RMotor, MStop - RSpeed100 'full speed on right
GOTO Save_Last
Hard_Left:
PULSOUT LMotor, MStop ' reverse left motor
PULSOUT RMotor, MStop - Speed075 ' full speed on right
GOTO Save_Last
Please help. I need to get this going asap. Thanks.
capabilities:
' { $STAMP BS2 }
contests where the
BOE-Bot will
a controlled
start feature
button starts the
BOE-Bot.
RMotor CON 12
LEDoff CON 1
field
field
RSpeed100 CON 245
Yes CON 1
No CON 0
temp VAR Byte
Run_Check:
No_Run:
Initialize:
Main:
middle sensor
Check_End:
if not at
end
course
Steer_Robot:
Left, Hard_Left]
Save_Last:
GOTO Main
At_End:
END
Read_Line_Follower:
FOR ledPos = 2 TO 6
sensor reading
NEXT
index
RETURN
Off_Line:
GOTO Steer_Robot
Hard_Right:
GOTO Save_Last
Right:
GOTO Save_Last
Straight:
GOTO Save_Last
Left:
GOTO Save_Last
Hard_Left:
GOTO Save_Last
please help if you know how to do this. i need to get this
going asap. thanks.
--- In basicstamps@y..., "idlereason" <idlereason@y...> wrote:
> Hi...
black
if
using
want
Whiskers
code
look
> capabilities:
> ' { $STAMP BS2 }
> contests where the
> BOE-Bot will
implements
> a controlled
> start feature
> button starts the
> BOE-Bot.
> RMotor CON 12
> LEDoff CON 1
> field
> field
> RSpeed100 CON 245
> Yes CON 1
> No CON 0
> temp VAR Byte
> Run_Check:
> No_Run:
> Initialize:
> Main:
> middle sensor
> Check_End:
steering
> if not at
> end
> course
> Steer_Robot:
> Left, Hard_Left]
> Save_Last:
> GOTO Main
> At_End:
> END
> Read_Line_Follower:
> FOR ledPos = 2 TO 6
> sensor reading
> NEXT
> index
> RETURN
> Off_Line:
> GOTO Steer_Robot
> Hard_Right:
left
> GOTO Save_Last
> Right:
left
> GOTO Save_Last
> Straight:
forward
> GOTO Save_Last
> Left:
right
> GOTO Save_Last
> Hard_Left:
right
> GOTO Save_Last
