frequency
Hello,
Can someone PLEASE help me. I am trying to figure out how to make the stamp
measure frequency using PULSIN with a BS2p. The manual says about this on page
241 under Explanation, but gives no example of how it can be used. I must use
PULSIN for the speed, The frequency range that I will be reading is 25Hz -
500Hz. I don't need to know the frequency just the Units.
I have tried to find a pattern using the inverse of the frequency and I got
lost.
Please Help.
AC
lost.
Please Help.
AC
Never mind about the last post I figured it out. But know I have another
problem. I need help with this math formula:
(( 1 / ( units*.00000075 )) / ( A / 2 )) *60 = B
the maximum value for units is 65535
the lowest value for units is 2670
The value for A will be between 12 and 4
Dose anyone know if the PAK-I can handle this formula?
AC
offline using our Fconvert program. Then you could read your units and A
values "on the fly". The rest is just multiply and divide.
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller
http://www.al-williams.com/awce/pak1.htm
> From: Anthony Conti [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=oWd9zmVmMgHkeNw10bA4hcf8N81GzfNy0vVanWiPB_oCdcBjWHfmav4apoAlqBLRKma9yfXHNa-gYw]aconti@s...[/url
> Sent: Tuesday, July 09, 2002 10:27 PM
> Subject: [noparse][[/noparse]basicstamps] frequency
> Hello,
> have another problem. I need help with this math formula:
> Thanks
> AC
> from the same email address that you subscribed. Text in the
