BS2p not working, how to test?
I have a BS2p 40 pin stamp I'm trying to use in a project.
It doesn't seem to be working and I was wondering what are some ways to
figure out if indeed it isn't working and what's wrong.
I've tried to connect it using a set-up that successfully works with a BS2.
I have changed the Default stamp mode to BS2p
The editor tells me that "Basic Stamp 2p not responding on com 1, check
serial cable connection, check power supply". I've checked both and they
are fine with the BS2. I've also checked to see if it's showing the correct
voltage on vin, vss, and vdd.
Is there any other things I can check to see what might be going wrong?
any advice appreciated!
I installed the basic stamp editor v1.32 and restarted my computer and now
it works.
Mystified but pleased, I now return you to your regularly scheduled
programming.
<exit stage left>
