AW: [basicstamps] Connect BS2 to Keyboard port
Hi Folks,
first thing is it seems that bs2 is too slow for the job, BSx works fine
though. PS 2-code is easy to find in the web, also the hardware connections.
Here is the code that I used, just the bit that does the actual shifting of
data into the PC.
One more important thing: when booting the PC you should have a Keyboard
connected to the PC because they do a confusing handshake before they start
working and that is not easy to simulate. One guy sent me a code once that
he said would do the job but it didn't work for me...
The bad thing about me is, taht I keep forgetting how I did things... sorry.
Hope it still works.
I also collected all the Mails when I first asked the group, so if anybody
wants me to forward all of them, just let me know.
Ok, here is the shifting code that works with BSX:
___________________________________________________-
hexen:
einszaehler=0 'counter used for parity bit
gosub nullschieben 'send a 0 as startbit
z1 = zeichen.bit0
gosub rausschicken 'send databits
z1 = zeichen.bit1
gosub rausschicken
z1 = zeichen.bit2
gosub rausschicken
z1 = zeichen.bit3
gosub rausschicken
z1 = zeichen.bit4
gosub rausschicken
z1 = zeichen.bit5
gosub rausschicken
z1 = zeichen.bit6
gosub rausschicken
z1 = zeichen.bit7
gosub rausschicken
gosub parity 'send parity-bit
gosub nullschieben 'send stopbit
return
rausschicken:
branch z1,[noparse][[/noparse]nullschieben,einsschieben] 'decide to send 0 or 1
nullschieben:
low daten
low clock 'clock out
input clock
return
einsschieben:
einszaehler=einszaehler+1 'parity-counter
input daten
low clock 'see above
input clock
return
parity:
if einszaehler.lowbit=0 then hopp
gosub nullschieben 'if number of ones odd then
return 'send zero
hopp:
gosub einsschieben 'if even send one
return
____________________________________________________________________________
__
Urspr
data into the PC.
hexen:
z1 = zeichen.bit0
z1 = zeichen.bit1
gosub rausschicken
z1 = zeichen.bit2
gosub rausschicken
z1 = zeichen.bit3
gosub rausschicken
z1 = zeichen.bit4
gosub rausschicken
z1 = zeichen.bit5
gosub rausschicken
z1 = zeichen.bit6
gosub rausschicken
z1 = zeichen.bit7
gosub rausschicken
return
rausschicken:
nullschieben:
low daten
input clock
return
einsschieben:
input daten
input clock
return
parity:
return 'send zero
hopp:
return
__
Urspr
They have a plug and play version...
Greetings, Uli
Urspr
