Pushbutton (on/off)
I know this has to be simple, but I just can't seem to get it.
I am using a BS2SX and a NX 1000 Experiment Board.
I want to turn an LED on with one push of a button, then turn it off again
with a push of the same button...........Reliably. The time it is pushed
allows a debounce routine (working fine).
Help please!
Lee
Registered Linux user #223705
Give me ambiguity or give me something else.
Help please!
Lee
operator to make this easy. Let's say your LED is on pin 0:
MyLED VAR Out0
Init:
OUTPUT 0
The code above names your pin and sets its direction to output. After you
debounce the switch, you can invert the state of the LED like this:
MyLED = ~MyLED
It's that simple.
-- Jon Williams
-- Parallax
In a message dated 7/4/02 9:51:24 AM Central Daylight Time,
dlwiggers@a... writes:
> Help please!
one step further.
I don't want to change states if I hold the button on. Then regardles of the
time element, I release the button, then push it again and it turns the LED
off.
I have programmed PLC's for years, so I have some learning and unlearning to
do.
I appreciate your help.
Lee
> You can use the Stamp's ability to alias variables and the bit invert
> MyLED VAR Out0
> Init:
> OUTPUT 0
> MyLED = ~MyLED
> It's that simple.
> -- Jon Williams
> -- Parallax
> > again with a push of the same button...........Reliably. The time it is
> > pushed allows a debounce routine (working fine).
> > Help please!
> Body of the message will be ignored.
