Math Question (Please Help) — Parallax Forums
edited 2002-07-04 15:09 in General Discussion
Hello,
I am working on a project for my car. I am planning to make a tachometer. I got
on to a few sights and got allot of info. I plan to make it using National's "
LM2917 ",an A/D converter, and the BS2p.
My problem is that National has in the typical applications has two tachometers,
and one says that 300Hz = 6000 RPM ( 6 cylinder Engine ). and that the other one
says 400Hz = 6000 RPM ( 8 cylinder engine ), but the one that I need (6
cylinder) is for current driven meter, I need the Voltage driven meter.
My question is, If 6V = 400Hz, then ?V = 300Hz. And how do you come up with it?
AC
    Anthony...I cannot comment on the specifics of your question but I would
    like to ask if you have ever installed an aftermarket tach on a car
    before....... I have, and I learned alot about how they work. I think if
    you even went to an auto parts store and read the instructions..( for free )
    you might gain some insight to your project. Remember that they are trying
    to make one tach that fits the largest variety of vehicles......since they
    do that, they will undoubtedly have to give up some info on how its
    done...in the form of...... " if you have a 4/8 cylinder, use the blue
    wire" "all 6 cyl use the green wire" "3 and 5 cylinders...go away"
    hope that helps
    Dave
    Sent: Thursday, July 04, 2002 1:11 AM
    Subject: [noparse][[/noparse]basicstamps] Math Question (Please Help)
    > Hello,
    I got on to a few sights and got allot of info. I plan to make it using
    National's " LM2917 ",an A/D converter, and the BS2p.
    tachometers, and one says that 300Hz = 6000 RPM ( 6 cylinder Engine ). and
    that the other one says 400Hz = 6000 RPM ( 8 cylinder engine ), but the one
    that I need (6 cylinder) is for current driven meter, I need the Voltage
    driven meter.
    with it?
    > Thanks
    > AC
