5 volt regs for Stamp
Archiver
The small onboard regulator marked p30A.
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jkXdN751u6Qy8mOdb7sPl3IeGqxmRrjHHJMRJm1S5vzXlu6z4N-EWKxgC_obslbpcTxf0hrb]Newzed@a...[/url
Sent: Tuesday, July 02, 2002 1:19 PM
Subject: Re: [noparse][[/noparse]basicstamps] 5 volt regs for Stamp
In a message dated 7/2/02 13:14:18 Eastern Daylight Time,
porter.sadler@s... writes:
> I have a couple of bs2 around with the 5volt regs blown.
> Classic not haveing a current limiting resistor when inputs switch to
> outputs. (stupid)
> anyone know where I can get a few (10-20) of these little chips.
Are you talking about the 7805 or the on-board regulator ?
Sid
> outputs. (stupid)
Sid
outputs. (stupid)
> outputs. (stupid)
Sid
Are you sure about the part number. The only p30a I know of is a 5kp30a
which is a 5000 watt transient voltage suppressor. If that is the right part
number you might try Parallax,
Sid
-=Randy
sadlpx <porter.sadler@s...> wrote: I have a couple of bs2 around with
outputs. (stupid)
from the same email address that you subscribed. Text in the Subject and Body of
Do You Yahoo!?
New! SBC Yahoo! Dial - 1st Month Free & unlimited access
I do not think you would be able to hurt this regulator by shorting the PIC
pins. The LM2936 has very good short circuit protection built in.
Shorting the pins can damage the PIC, which in turn might cause the PIC to
ask for more than the 50 milliamps available from the regulator, forcing it
to go into shut down mode.
fwiw
Steve
At 10:43 AM 7/2/02 -0700, you wrote:
> Go to www.digikey.com and do a search for LM7805
>-=Randy
>outputs. (stupid)
>Do You Yahoo!?
sargent@s... wrote:
> I believe the stamp2 uses an LM2936 5 volt regulator in surface mount form.
> fwiw
> Steve
> >-=Randy
> >outputs. (stupid)
> >Do You Yahoo!?
