Button comand behavior
Hi All,
In my book it says that the BUTTON command is called from within loops. However,
it seems to be called from anywhere, anytime. What is the "proper" behavior of
this command?
I am constructing a device that the user needs to be able to configure before
operation, for example the user will select an operational mode and then set a
parameter, then use the device.
Thanks!
Jonathan Peakall
www.madlabs.info
this command?
Thanks!
Jonathan Peakall
www.madlabs.info
