PBasic Program ? response of servo to Sonar Distance
I have managed to write simple pbasic code for BS2 stamp that
allows a servo to respond to distances produced by my sonar...
Problem seems to be in my code... Below is not the exact code
just then basic concept:
Sonarsweeep:
'Distance found by sonar'
if distance< 60 or distance > 80 then Sonarsweep
if distance > 60 or distance<80 then B1
B1:
'rotate servo 180'
'pause for servo full turn'
goto Sonarsweep
Problem:
If distance consistently registers <60 or > 80 the servo will pulse
or shake at every given reading until this statement is not true... I
would like the servo to make the full turn on first true statement
and if the statement is between <60 and >80 again I would like
to ignore it and return to sonar sweep until it is not true. This is a
first step to having many responses to differing distance
readings with a few servos. If you have any advice it would be
much appreciated.
MLD
Sonarsweeep:
B1:
'rotate servo 180'
goto Sonarsweep
Problem:
much appreciated.
MLD
that will give you a sweep in the incremental degrees you desire. Then you
can create a LOOKUP table of these values to control the position.
Your program can that set the sonar to a given sweep angle, take a
measurement, then decide to proceed to the next value or not.
Note: You may not have used it in your actual code ... be careful of the use
of "B1" as an address label as this is an internal variable name used by the
Stamp compiler.
-- Jon Williams
In a message dated 6/30/02 12:14:31 PM Central Daylight Time,
mldunleavy@y... writes:
> Sonarsweeep:
> B1:
> 'rotate servo 180'
> goto Sonarsweep
> Problem:
> much appreciated.
> Thanks
> MLD
