Daisy Chain the 74HC595
I want to use 4 of these shift registers (74HC595) using the same
stamp pins - daisy chain. The example in the "App Notes" in the BS2
manual doesn't get into that details. I understand that the OE line
on the first 74HC595 is connected to the Data pin of the second and
both of them share the clk and latch lines.
My confusion is how to address a particular 74HC595 in the chain.
What should be put in the code that will make the command to go to,
let's say the 3rd 74HC595 but ignored by all other three chips. I
am just not sure how to do that?
Many thanks in advance...
Al
Al
Daisy chaining the 595 is simple.
First, change your shiftout msbfirst to lsbfirst. That was if you write
1000 0000 the the "1" is the first 595 output, or Qa. Makes it much easier
to program.
Second, to send to multiple 595s you would write
Shiftout pin, clk, lsbfirst, [noparse][[/noparse]pattern]
shiftout pin, clk, lsbfirst, [noparse][[/noparse]pattern1]
shiftout pin, clk, lsbfirst, [noparse][[/noparse]pattern2]
pulsout latch, 10
Pattern goes to the last 595 in the string, pattern1 goes to the second 595,
and pattern2 goes to the first 595. This gets confusing when you are trying
to control things, so I always send the pattern I want in the last chip
first, then the pattern I want in the second chip and finally the pattern I
want in the first chip.
If you want to send, for example,
00001000, which = 8 decimal, you could send
shiftout pin, clk, lstfirst, [noparse][[/noparse]8]
pulsout latch, 10
In other words, decimal numbers work just as well as binary codes.
Connect pin 9 if the first chip to pin 14 of the second chip, pin 9 of the
second chip to pin 14 of the third chip, and so on. You can daisy chain up
to at least 10, giving you 80 outputs with one I/O line.
Hope I expressed this clearly.
Sid
one device to the serial input of the next. The clock and latch lines for
all devices are connected together.
Since the data is sent down the stream serially, it's not possible to address
one without impacting the others. Imagine this chain:
[noparse][[/noparse] Stamp ]--[noparse][[/noparse] A ]--[noparse][[/noparse] B ]--[noparse][[/noparse] C ]--[noparse][[/noparse] D ]
To get information into device "C" it must pass through "A" and "B" first.
Device "D" is also affected due to the information moving through the chain
(if you just do three SHIFTOUTs to get information into C, what was in A will
now be in D). What you need to do, then, is create a subroutine that sends
the current data for all four devices -- in reverse order (D, C, B, A). Like
this:
Update_595_Outputs:
SHIFTOUT Dpin, Cpin, MSBFirst, [noparse][[/noparse]DevD, DevC, DevB, DevA]
RETURN
Whenever there is a change in any of your device storage variables, call this
routine. For any device that had no change in its variable, there will be no
change at the outputs.
I hope this helps.
-- Jon Williams
In a message dated 6/30/02 8:58:59 AM Central Daylight Time,
brownstamp@y... writes:
much over the BS2learning process through this group and N&V
articles. Many thanks.
Al
--- In basicstamps@y..., Newzed@a... wrote:
> For Al
write
much easier
> to program.
> pulsout latch, 10
second 595,
are trying
chip
pattern I
> pulsout latch, 10
9 of the
chain up
> Sid
